[GeoNetwork-users] Adding Schema plug-in to a running GN
I have one question. Is it possible to add a schema plug-in to a running Geonetwork?The only instruction I have found so far, only explains how to add a schema plug-in into source code and then compile it to produce the war file. [I am using Tomcat servlet]At the moment we have a geonetwork service running on our server and I want to add one schema plug-in.
Thanks for your help in advanceMani
