I want to add new parameters to "Advanced search". To do this I added new
fields in search form in main-page.xsl.
After this I modified GN source code:
* fao.geonet.constants.Geonet.java
- added new search element
* fao.geonet.services.util.MainUtil.java
- added new element to array "elData"
- added new element declaration
- added new String declaration
- new "if" instruction for created element (similar to already
existing elements)
* fao.geonet.services.main.Search.java
existing elements)
At the end I added xml part to file xml/search/lucene.xsl:
Described method works for element gmd:denominator, but only for this
element. I did everything in the same way for elements: gmd:alternateTitle,
gmd:topicCategory, but I get everytime 0 results. What I do wrong or maybe I
missed something ??
Could you tell me which version of Geonetwork you are using?
I am using 2.03 and had to modify the search/iso19115.xsl file as well. I
did not modify fao.geonet.services.main.Search.java.
Also, before the new search items will work you need to stop geonetwork and
clear the index files from the web\WEB-INF\lucerne then restart. This will
allow the new index files to be created.
Byron
Lukasz_Sobotowski wrote:
existing elements)
existing elements)
gmd:alternateTitle, gmd:topicCategory, but I get everytime 0 results. What
I do wrong or maybe I missed something ??
I'm using GN 2.1 RC.
I tried to modify xml/search/iso19139.xsl before, but it didn't help. The
clue to solve this problem was clearing lucene index files, only then
changes made in xml/search/iso19139.xsl works.
You were right also about Search.java. There is no need to modify
fao.geonet.services.main.Search.java file. It works fine without it.
Thanks for your help.
ByronC wrote:
Hello Lukasz,
and clear the index files from the web\WEB-INF\lucerne then restart. This
will allow the new index files to be created.
Byron
existing elements)
existing elements)
What I do wrong or maybe I missed something ??
do i have to compile GN by myself to change the search functions? I have
batch imported metadata files, which are not displayed in GN, but are
visible in the Postgres database. I think thats because the metadata is not
fully completed. Now i wanted to force Geonetwork to show all metadata. You
have an idea how to do that?
thanks ans best regards
roger mrzygŁocki (PL)
existing elements)
existing elements)
