[GeoNetwork-users] Address already in use/ bind
Hello. Installed GeoNetwork on a few PCs. On one of them, starting the
server includes
WARN: failed SelectChannelConnector@anonymised.com:8080
java.net.BindException> Address already in use: bind
Plus some extra messages. How to avoid that? On all other PCs, instead of
WARN there comes
INFO: started and the similar address.
Also the GeoNetwork does not work but says the webpage cannot be found.
Java version : 14.0-b16, elsewhere e.g. 14.3-b01, but probably does not
matter here.
Arto
hi,
it means some other process is already using port 8080. I think maybe Skype
or so could do that.
You can change the port for GeoNetwork in that case, by changing it in
bin/jetty.xml.
Kind regards
Heikki Doeleman
On Tue, Mar 30, 2010 at 11:50 AM, Arto Vuorela <arto.k.vuorela@anonymised.com>wrote:
server includes
WARN there comes
matter here.
Arto
Download Intel&#174; Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
GeoNetwork-users mailing list
