Hi.
I have an installation using MySQL database.
I had 3500 records on my server copied via harvesting.
Then I deleted them directly from DB "Delete from Metadata where harvested
='y' "
Now I have only 30 Records on my DB, but when using WEB administration
tool, "MYMETADATA" it says:
"Aggregated results matching search criteria : 3472"And lots of blank
results pages, so I have to go to the last to see my records.How can I
reset this results to the actual 30 records on my DB??Thanks
hi,
if you directly delete metadata from your db like that, GeoNetwork's Lucene
index is not updated and still contains those metadata.
Please try logging in as administrator, and find 'rebuild index'. After
this, your GeoNetwork installation should again reflect the contents of
your DB.
Kind regards
Heikki Doeleman
On Mon, May 28, 2012 at 9:44 PM, Leonardo Dobles <hableconleo@anonymised.com>wrote:
Hi.
='y' "
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
