Hi Oscar,
I'm interested in doing the same type of operation.
However the methods I'm using at the moment is by using parentIdentifier as
the link to a series of metadata records.
This is a bit clunky and I'm implementing it at the database level by
including a separate column in the metadata table called parent_id. I can
then easily find all metadata records that are in the series.
This is just a work around that hopefully will be addressed more elegantly in
the future.
Tony Hunter
GIS Professional - Asia Pacific (GISP - Asia Pacific)
Risk & Impact Analysis Group
Geospatial & Earth Monitoring Division
Geoscience Australia
GPO Box 378, Canberra, ACT 2601, Australia
( +61 2 62499362 Fax: +61 2 62499911
x Tony.Hunter@anonymised.com
Internet: http://www.ga.gov.au
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of Oscar
Gomez
Sent: Friday, 4 July 2008 4:49 PM
To: Hockaday John
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Ancilliary datasets [SEC=UNCLASSIFIED]
Hi John,
It's ok, I was just wondering whether it was possible or not.
So thank you for your answer, it saved a lot of time of searching, reading,
and testing.
Best,
Oscar
On Fri, Jul 4, 2008 at 1:51 AM, <John.Hockaday@anonymised.com> wrote:
Hi Oscar,
Officially "no" but it looks like there is a need in the revised ISO 19115
metadata standard for something like "metadataFileIdentifier" in the
"LI_Source" that could have an "xlink" attribute to link to the full
metadata
record.Sorry I can't give you a "yes".
John
> Behalf Of Oscar Gomez
> Sent: Thursday, 3 July 2008 11:05 PM
> To: Geonetwork Users
> Subject: [GeoNetwork-users] Ancilliary datasets
> Hi!
> I have one question. With ISO19139, under lineage, you can
> specify that for
> creating a dataset, other datasets as "source" have been used.
> If the "source" metadata would already exist in GeoNetwork,
> is there any
> chance to point (and hyperlink) to the source dataset from the current
> metadata? I would like to be able to "trace upstream" to the original
> datasets.
> Thanks in advance,
> Oscar
> European Commission, JRC
> Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
> Studies have shown that voting for your favorite open source project,
> along with a healthy diet, reduces your potential for chronic lameness
> and boredom. Vote Now at http://www.sourceforge.net/community/cca08
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
