Hi Francois,
That sounds like great work I would definitely be interested in using it.
The reason I added the additional field was so I could find any record
related in a series of records i.e not just the nearest relative. This is a
type of recursive call.
We want to be able to notify programmatically when component datasets, in a
series, are updated.
Are you considering providing methods for calling the functionality you
described, or will it only be available manually?
Tony Hunter
GIS Professional - Asia Pacific (GISP - Asia Pacific)
Risk & Impact Analysis Group
Geospatial & Earth Monitoring Division
Geoscience Australia
GPO Box 378, Canberra, ACT 2601, Australia
( +61 2 62499362 Fax: +61 2 62499911
x Tony.Hunter@anonymised.com
Internet: http://www.ga.gov.au
-----Original Message-----
[mailto:francois-xavier.prunayre@anonymised.com]
Sent: Friday, 4 July 2008 5:58 PM
To: Oscar Gomez; Hunter Tony
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Ancilliary datasets [SEC=UNCLASSIFIED]
Hi Tony and Oscar,
On ven, 2008-07-04 at 09:49 +0200, Oscar Gomez wrote:
Hi Tony,
Thank you for the tip. For me that workaround you're implementing will
definitely work. I think it's the only way through.
we are also working on managing parent/child relationship in GeoNetwork.
What has been made so far:
* in the editor, added a popup to the parentIdentifier field in order
to do a search in the local catalogue and set the parentIdentifier to
the uuid of the selected record.
* in the metadata view, added an hyperlink to go to the metadata of the
parent (using the uuid)
* in the index, allow search on parentIdentifier in order to search for
child
* in the search results, added a button to search for child of each
records.
This is still under development but will be able to share this in the
comming weeks.
Tony, why did you add a column to the table ?
Ciao. Francois
Once you have implemented it at database level, do you have implemented
something at presentation level (I mean, on the web interface) for being
able to navigate from one metadata to his parent (or derived) dataset(s)?
Best Regards,
Oscar
*Oscar GOMEZ PRIETO*
*Joint Research Centre
European Commmission *
*Institute for Environment and Sustainability
Rural, Water and Ecosystem Resources Unit *
*Building 26A Office nº132 TP 262
Via Enrico Fermi 2749
I-21027, ISPRA(VA) Italy
Tel. **+39 - 03.32.78.38.24
E-mail: **oscar.gomez@anonymised.com* <oscar.gomez@anonymised.com>*
Unit Web site: **http://agrienv.jrc.it/* <blocked::http://agrienv.jrc.it/>\*
*DISCLAIMER:** The views expressed are purely those of the writer and may
not in any circumstances
be regarded as stating an official position of the European Commission.*
*P** ** **Please consider the environment before printing this e-mail***
On Fri, Jul 4, 2008 at 9:34 AM, <Tony.Hunter@anonymised.com> wrote:
> Hi Oscar,
> I'm interested in doing the same type of operation.
> However the methods I'm using at the moment is by using parentIdentifier
as
> the link to a series of metadata records.
> This is a bit clunky and I'm implementing it at the database level by
> including a separate column in the metadata table called parent_id. I can
> then easily find all metadata records that are in the series.
> This is just a work around that hopefully will be addressed more
elegantly
> in
> the future.
> Tony Hunter
> From: geonetwork-users-bounces@lists.sourceforge.net
> [mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
Oscar
> Gomez
> Sent: Friday, 4 July 2008 4:49 PM
> To: Hockaday John
> Hi John,
> It's ok, I was just wondering whether it was possible or not.
> So thank you for your answer, it saved a lot of time of searching,
reading,
> and testing.
> Best,
> Oscar
> On Fri, Jul 4, 2008 at 1:51 AM, <John.Hockaday@anonymised.com> wrote:
> > Hi Oscar,
> > Officially "no" but it looks like there is a need in the revised ISO
> 19115
> > metadata standard for something like "metadataFileIdentifier" in the
> > "LI_Source" that could have an "xlink" attribute to link to the full
> > metadata
> > record.
> > Sorry I can't give you a "yes".
> > John
> > > Behalf Of Oscar Gomez
> > > Sent: Thursday, 3 July 2008 11:05 PM
> > > To: Geonetwork Users
> > > Subject: [GeoNetwork-users] Ancilliary datasets
> > > Hi!
> > > I have one question. With ISO19139, under lineage, you can
> > > specify that for
> > > creating a dataset, other datasets as "source" have been used.
> > > If the "source" metadata would already exist in GeoNetwork,
> > > is there any
> > > chance to point (and hyperlink) to the source dataset from the
current
> > > metadata? I would like to be able to "trace upstream" to the original
> > > datasets.
> > > Thanks in advance,
> > > Oscar
> > > European Commission, JRC
> > > Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
> > > Studies have shown that voting for your favorite open source project,
> > > along with a healthy diet, reduces your potential for chronic
lameness
> > > and boredom. Vote Now at http://www.sourceforge.net/community/cca08
> > > _______________________________________________
> > > GeoNetwork-users mailing list
> > > GeoNetwork-users@lists.sourceforge.net
> > > https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> > > GeoNetwork OpenSource is maintained at
> along with a healthy diet, reduces your potential for chronic lameness
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
