Hi Oscar,
It sounds to me that AM - administrative boundaries is a hierarchyLevel of
'series' and the other titles (AM1990, AM1993 ...) are datasets.
Thanks.
John
-----Original Message-----
Sent: Wednesday, 24 September 2008 12:53 AM
To: Hunter Tony
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Ancilliary datasets [SEC=UNCLASSIFIED]Hi François,
Did you finally managed to include the parentIdentifier? Is
it on the SVN
version?By the way, is there any plan for adding a "version" element?
I mean, if you
have for example a dataset (let's call it AM - administrative
boundaries),
that is being updated over time, so you have different
versions of the same
dataset, corresponding to different times (AM1990, AM1993,
AM2001, AM2002,
...), is there any chance in GeoNetwork to have this
relationship, so you
can navigate from version to version? I would call it
"historical versions".Thanks in advance,
Oscar
On Mon, Jul 7, 2008 at 3:04 AM, <Tony.Hunter@anonymised.com> wrote:
> Hi Francois,
> That sounds like great work I would definitely be
interested in using it.
> The reason I added the additional field was so I could find
*any* record
> related in a series of records i.e not just the nearest
relative. This is a
> type of recursive call.
> We want to be able to notify programmatically when
component datasets, in a
> series, are updated.
> Are you considering providing methods for calling the
functionality you
> described, or will it only be available manually?
> Tony Hunter
> GIS Professional - Asia Pacific (GISP - Asia Pacific)
> Risk & Impact Analysis Group
> Geospatial & Earth Monitoring Division
> Geoscience Australia
> GPO Box 378, Canberra, ACT 2601, Australia
> ( +61 2 62499362 Fax: +61 2 62499911
> x Tony.Hunter@anonymised.com
> Internet: http://www.ga.gov.au
> From: Francois-Xavier Prunayre [mailto:
> francois-xavier.prunayre@anonymised.com]
> Sent: Friday, 4 July 2008 5:58 PM
> To: Oscar Gomez; Hunter Tony
[SEC=UNCLASSIFIED]
> Hi Tony and Oscar,
> On ven, 2008-07-04 at 09:49 +0200, Oscar Gomez wrote:
> > Hi Tony,
> > Thank you for the tip. For me that workaround you're
implementing will
> > definitely work. I think it's the only way through.
> we are also working on managing parent/child relationship
in GeoNetwork.
> What has been made so far:
> * in the editor, added a popup to the parentIdentifier
field in order
> to do a search in the local catalogue and set the
parentIdentifier to
> the uuid of the selected record.
> * in the metadata view, added an hyperlink to go to the
metadata of the
> parent (using the uuid)
> * in the index, allow search on parentIdentifier in order
to search for
> child
> * in the search results, added a button to search for child of each
> records.
> This is still under development but will be able to share
this in the
> comming weeks.
> Tony, why did you add a column to the table ?
> Ciao. Francois
> > Once you have implemented it at database level, do you
have implemented
> > something at presentation level (I mean, on the web
interface) for being
> > able to navigate from one metadata to his parent (or
derived) dataset(s)?
> > Best Regards,
> > Oscar
> > *Oscar GOMEZ PRIETO*
> > *Joint Research Centre
> > European Commmission *
> > *Institute for Environment and Sustainability
> > Rural, Water and Ecosystem Resources Unit *
> > *Building 26A Office nº132 TP 262
> > Via Enrico Fermi 2749
> > I-21027, ISPRA(VA) Italy
> > Tel. **+39 - 03.32.78.38.24
> > E-mail: **oscar.gomez@anonymised.com* <oscar.gomez@anonymised.com>*
> > Unit Web site: **http://agrienv.jrc.it/* <blocked::
> http://agrienv.jrc.it/>\*
> > *DISCLAIMER:** The views expressed are purely those of
the writer and may
> > not in any circumstances
> > be regarded as stating an official position of the
European Commission.*
> > *P** ** **Please consider the environment before printing
this e-mail***
> > On Fri, Jul 4, 2008 at 9:34 AM, <Tony.Hunter@anonymised.com> wrote:
> > > Hi Oscar,
> > > I'm interested in doing the same type of operation.
> > > However the methods I'm using at the moment is by using
> parentIdentifier as
> > > the link to a series of metadata records.
> > > This is a bit clunky and I'm implementing it at the
database level by
> > > including a separate column in the metadata table
called parent_id. I
> can
> > > then easily find all metadata records that are in the series.
> > > This is just a work around that hopefully will be addressed more
> elegantly
> > > in
> > > the future.
> > > Tony Hunter
> > > From: geonetwork-users-bounces@lists.sourceforge.net
> > > [mailto:geonetwork-users-bounces@lists.sourceforge.net]
On Behalf Of
> Oscar
> > > Gomez
> > > Sent: Friday, 4 July 2008 4:49 PM
> > > To: Hockaday John
[SEC=UNCLASSIFIED]
> > > Hi John,
> > > It's ok, I was just wondering whether it was possible or not.
> > > So thank you for your answer, it saved a lot of time of
searching,
> reading,
> > > and testing.
> > > Best,
> > > Oscar
> > > On Fri, Jul 4, 2008 at 1:51 AM, <John.Hockaday@anonymised.com> wrote:
> > > > Hi Oscar,
> > > > Officially "no" but it looks like there is a need in
the revised ISO
> > > 19115
> > > > metadata standard for something like
"metadataFileIdentifier" in the
> > > > "LI_Source" that could have an "xlink" attribute to
link to the full
> > > > metadata
> > > > record.
> > > > Sorry I can't give you a "yes".
> > > > John
> > > > > [mailto:geonetwork-users-bounces@lists.sourceforge.net] On
> > > > > Behalf Of Oscar Gomez
> > > > > Sent: Thursday, 3 July 2008 11:05 PM
> > > > > To: Geonetwork Users
> > > > > Subject: [GeoNetwork-users] Ancilliary datasets
> > > > > Hi!
> > > > > I have one question. With ISO19139, under lineage, you can
> > > > > specify that for
> > > > > creating a dataset, other datasets as "source" have
been used.
> > > > > If the "source" metadata would already exist in GeoNetwork,
> > > > > is there any
> > > > > chance to point (and hyperlink) to the source
dataset from the
> current
> > > > > metadata? I would like to be able to "trace upstream" to the
> original
> > > > > datasets.
> > > > > Thanks in advance,
> > > > > Oscar
> > > > > European Commission, JRC
> > > > > Sponsored by: SourceForge.net Community Choice
Awards: VOTE NOW!
> > > > > Studies have shown that voting for your favorite open source
> project,
> > > > > along with a healthy diet, reduces your potential
for chronic
> lameness
> > > > > and boredom. Vote Now at
> http://www.sourceforge.net/community/cca08
> > > > > _______________________________________________
> > > > > GeoNetwork-users mailing list
> > > > > GeoNetwork-users@lists.sourceforge.net
> > > > > GeoNetwork OpenSource is maintained at
> > > > > http://sourceforge.net/projects/geonetwork
> > > Sponsored by: SourceForge.net Community Choice Awards:
VOTE NOW!
source project,
> > > along with a healthy diet, reduces your potential for
chronic lameness
> Francois Xavier Prunayre
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac Cedex
> Tel : + 33 (0)6 34 11 71 75
> http://www.camptocamp.com
This SF.Net email is sponsored by the Moblin Your Move
Developer's challenge
Build the coolest Linux based applications with Moblin SDK &
win great prizes
Grand prize is a trip for two to an Open Source event
anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
