[GeoNetwork-users] Any chance the GUID is not being properly inserted? (display of record content is not quite right) [SEC=UNCLASSIFIED]
Hi Guys
Is there any chance that GN 3.4.x is not properly replacing GUID in to imported metadata records?
Or maybe something else?
Suggestions gratefully received
E
When I go to display a imported record title = "Nutrient Status of Australian Agricultural Soils (1989-1999) pH (CaCl2) (0 - 15cm) ESRI Point ShapeFiles - point excluded from surface calculations"
It displays the title as:
       ["GPO 2182","Nutrient Status of Australian Agricultural Soils (1989-1999) pH (CaCl2) (0 - 15cm) ESRI Point ShapeFiles - point excluded from surface calculations"]
In Display mode XML view I get:
<apiError>
<code>resource_not_found</code>
<description>
Record with UUID '3314783e-36e6-4c74-819d-29977f5a64a7' not found in this catalog
</description>
<message>ResourceNotFoundException</message>
</apiError>
If I go to edit it, GN cannot seem to find anything to edit (see previous few lines)
This also means I can't seem to delete the records.
    Note: "GPO 2182" is the first line of
<mdb:MD_Metadata ...
   <mdb:identificationInfo>
      <mri:MD_DataIdentification id="DI01_cust_9nn_logo.gif">
         <mri:citation>
            <cit:CI_Citation>
               <cit:title>
                  <gco:CharacterString>Nutrient Status of Australian Agricultural Soils (1989-1999) pH (CaCl2) (0 - 15cm) ESRI Point ShapeFiles - point excluded from surface calculations</gco:CharacterString>
               </cit:title>
               <cit:citedResponsibleParty>
                  <cit:CI_Responsibility>
                     <cit:party>
                        <cit:CI_Organisation id="AG_DAWR_exNLWRA">
                           <cit:name>
                                    Aust Govt Department of Agriculture and Water Resources (formerly: National Land and Water Resource Audit (NLWRA))
                           </cit:name>
                           <cit:contactInfo>
                              <cit:CI_Contact>
                                 <cit:address>
                                    <cit:CI_Address>
                                       <cit:deliveryPoint>
                                          <gco:CharacterString>GPO 2182</gco:CharacterString>
                                       </cit:deliveryPoint>
                                 </cit:address>
                              </cit:CI_Contact>
                           </cit:contactInfo>
                       </cit:CI_Organisation>
                     </cit:party>
                  </cit:CI_Responsibility>
               </cit:citedResponsibleParty>
           </cit:CI_Citation>
         </mri:citation>
      </mri:MD_DataIdentification>
   </mdb:identificationInfo>
</mdb:MD_Metadata>
[cid:image001.png@anonymised.com]
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
(attachments)
