[GeoNetwork-users] API Add record Error
Hello all,
I´m trying to add a record from a XML file via the Geonetwork API (/api/0.1/records). To start I tried the "Try it out feature" of the API documentation ( and only changed the metadataType to Metadata and added the xml file. Unfortunately I get an Error:
  "message": "MultipartException",
  "code": "unsatisfied_request_parameter",
  "description": "The current request is not a multipart request"
Im not sure if there is anything I could have done wrong or if this some kind of Bug.
Any advice is appreciated!
Thanks in advance
