I'm tryng to set the XSLT conversion from ISO19139 to ISO19115-3.2018
I saved the xsl file in the folder
/root/core-geonetwork/web/src/main/webapp/xsl/conversion/import/fromISO19139.xsl
I also put the folder
/root/core-geonetwork/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115-3.2018/convert/ISO19139/
Here:
But I got this error:
Error at xsl:call-template on line 105 column 63 of fromISO19139.xsl:
XTSE0650: No template exists named getNamespacePrefix
Error at xsl:call-template on line 110 column 75 of fromISO19139.xsl:
XTSE0650: No template exists named add-iso19115-3.2018-namespaces
Error at xsl:call-template on line 205 column 91 of fromISO19139.xsl:
XTSE0650: No template exists named writeCharacterStringElement
Error at xsl:call-template on line 227 column 83 of fromISO19139.xsl:
Error at xsl:call-template on line 251 column 67 of fromISO19139.xsl:
Error at xsl:call-template on line 266 column 79 of fromISO19139.xsl:
Is there something I'm still missing or doing wrong?
Thanks in advance
Bartolomeo
Bartolomeo Ventura, PhD
Eurac Research
Institute for Earth Observation
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/>
