I am using web services to insert metadata records. I would like to assign them categories that i've created. To this end, as the services manual says, I am trying to use the element "category". However, whenever I specify a category (that is different to "_none_") the service returns an internal server error.
In order to check that the internal name of the category is the same i am using, i have assigned the category by using the web interface, and later I have got it by using the service "xml.metadata.get"
Any suggestions?
