Hi Jose,
I really need help desperately.
1. I installed 3.4.2.war
1. I copied iso19139.anzlic plugin from here to schema-plugins folder
https://github.com/metadata101/iso19139.anzlic
Question:
Where do I add this: src/main/resources/config-spring-geonetwork.xml<https://github.com/metadata101/iso19139.anzlic/commit/8017c3b3399105d18a617815660cae7ea20403b0#diff-efa483686f42a79ef50333db5c3ae74a>?
@@ -5,5 +5,5 @@
xsi:schemaLocation="http://www.springframework.org/schema/beans/spring-beans.xsd<http://www.springframework.org/schema/beans%20http:/www.springframework.org/schema/beans/spring-beans.xsd>">
<bean id="iso19139ANZLICSchemaPlugin"
- class="org.fao.geonet.schema.iso19139anzlic.ISO19139ANZLICSchemaPlugin"/>
+ class="org.fao.geonet.schema.iso19139.ISO19139SchemaPlugin"/>
</beans>
1. I have problem with iso19139.anzlic plugin.
If a record has schemaid = ‘iso19139.anzlic’, in edit mode, it does not show the ‘Associated Resources’ for me to attach a parent.
1. If a record has schemaid = ‘iso19139’, ‘Associated Resources’ is present.
2. Please see the screenshots in the WORD document to make what I am trying to say clearer.
Is there anything else I need to add to make the iso19139.anzlic to show ‘‘Associated Resources’ in edit mode?
Any help/lead will be much appreciated.
Thanks.
Peck
Peck Choo Tan I Analyst Programmer
GNS Science I Te Pῡ Ao
1 Fairway Drive, Avalon 5010, PO Box 30368, Lower Hutt 5040, New Zealand
Ph 04 570 4739 I Mob 021 2178684
http://www.gns.cri.nz/ | Email: p.tan@...1298...
Notice: This email and any attachments are confidential and may not be used, published or redistributed without the prior written consent of the Institute of Geological and Nuclear Sciences Limited (GNS Science). If received in error please destroy and immediately notify GNS Science. Do not copy or disclose the contents.
(attachments)
AssocResources.docx (340 KB)
