I have a problem with Geonetwork 3.4.0 when I try to insert a new metadata
based on Dublin Core template.
In version 3.2.0 when I create a new Dublin Core metadata, the section
Associated Resources (the attached image, associatedResources-3.2.0.png)
appears in the form.
In version 3.4.0, the rest of the fields appear as well, but this
Associated Resources is missing.
I understand that this section is associated to a field named
<dct:references xmlns:geonet="http://www.fao.org/geonetwork">, but I put
this on a template in the database, and the section is still missing in the
user interface.
I really need this section to attach a preview of a document in the
metadata.
I appreciate your help with this issue.
Best regards!
LUIS FERNANDO ORTIZ REYES
INGENIERO DE SISTEMAS
ESP. EN PROYECTOS INFORMÁTICOS
UNIVERSIDAD DISTRITAL
BOGOTÁ, COLOMBIA
In 3.4.x was changed the configuration of the metadata editor, previously
was in a database setting, but now it's in the config-editor.xml file and
seem in Dublin Core is missing.
I have created this issuehttps://
github.com/geonetwork/core-geonetwork/issues/2601 to track it as even when
adding the sidePanel section, it seems no working.
Jose García
On Tue, Mar 6, 2018 at 8:38 PM, Lucho <lucho1524@anonymised.com> wrote:
Hi list!
user interface.
metadata.
Best regards!
BOGOTÁ, COLOMBIA
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
