Sorry, those are the line related to geonetwork.I'm using intenl db, not postgresql or mysql.
E.
Date: Mon, 30 Jan 2012 17:41:33 +0100
Subject: Re: [GeoNetwork-users] authentication problem
To: frippe12573@anonymised.com
CC: geonetwork-users@lists.sourceforge.net
hi,
those messages don't indicate an abnormal situation.
You're sure you don't have anything like
Failed to create datastore for jdbc:postgresql_postGIS://localhost:5432/geonetwork
or other things related to the DB in your log ?
Are you using the default H2 DB, or changed to e.g. Postgres ?
Or any other error messages ? Maybe try setting log level to DEBUG.
Kind regardsHeikki Doeleman
On Mon, Jan 30, 2012 at 5:33 PM, Eugenio Trumpy <frippe12573@anonymised.com> wrote:
Hi,i found this in the log file:
30-gen-2012 12.57.11 org.apache.catalina.loader.WebappClassLoader clearReferencesThreadsGRAVE: The web application [/geonetwork] appears to have started a thread named [ElementEventQueue.QProcessor-1] but has failed to stop it. This is very likely to create a memory leak.
30-gen-2012 12.57.11 org.apache.catalina.loader.WebappClassLoader clearReferencesThreadsGRAVE: The web application [/geonetwork] appears to have started a thread named [Thread-16] but has failed to stop it. This is very likely$
30-gen-2012 12.57.18 org.apache.catalina.loader.WebappClassLoader validateJarFileINFO: validateJarFile(/home/igg/apache-tomcat-6.0.32/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-6.1.14.jar) - jar not loaded. See Servlet Spec Secion 9.7.2. Offending class: javax/servlet/Servlet.class
E.
Date: Mon, 30 Jan 2012 17:28:11 +0100
hi Eugenio,
it's likely your database connection does not work. Anything in the GeoNetwork logs about that ?
On Mon, Jan 30, 2012 at 5:22 PM, Eugenio Trumpy <frippe12573@anonymised.com> wrote:
Hi to all,
i have a problem with admin and users authentication.
How does the authentication system work?Once i try to login i receive this message: THE REQUESTED OPERATION COULD NOT BE PERFORMED.
NullPointerException :
happens when i try to login geonetwork with admin credential,
i try then with the simple user credential, but i have the same result.
It seems that the authentication process does not work fine.
I try to restart geonetwork but i have the same result.
I wondering if there is a way to restart the authentication system, or
if there is a way to change the admin password from outside the geonetwork
enviroment, using the command line.
At least, in the worste case, there is a way to backup the data from outside
geonetwork
to restore those in a newer geonetwork version?Thanks
E.P.S. Geonetwork 2.4.3 on tomcat 6.0.18, ubuntu server 9.06
Try before you buy = See our experts in action!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-dev2
GeoNetwork-users mailing list
