Hi list,
I would like to automatically create metadata from shapefiles or rasters (extent, EPSG, etc.) : from data file, l want to create ISO 19139 XML file. I like Metadator tool (https://github.com/Guts/Metadator)but Metadator uses an interface and isn't compatible with rasters. So I would prefer a command-line tool.
Do you use Metadator or another tool ? I have looked for another free tool on the web but I haven't found the perfect tool ! Maybe I could use gdal python library but it seems to me that requires a lot of work.
Thank you in advance for your ideas,
/Sophie MOLLARD/
/Pôle Géomatique/
/MSHE C. N. Ledoux (USR 3124) <http://mshe.univ-fcomte.fr>/
/Université de Franche-Comté/
/Tél : 03.81.66.51.55/
Hi Sophie,
2016-07-20 15:09 GMT+02:00 Sophie Mollard <
sophie.mollard@anonymised.com>:
Hi list,
https://github.com/talend-spatial/workspace-metadata-crawler/ may be of
interest.
HTH.
Francois
/Sophie MOLLARD/
/Pôle Géomatique/
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
GeoNetwork-users mailing list
