Geoserver is deployed to a temporal work folder in jetty when it's started.
If you plan to add layers in GeoServer, it's better you unzip it in the same
folder where it's located the war file. If you do this, it's used that
folder when jetty it's started.
Jose García
GeoCat bv
On Fri, Jan 14, 2011 at 2:55 PM, Tacot <cfab13@anonymised.com> wrote:
Do I have to unzip GEOSERVER.WAR somewhere?
Because how Geonetwork use it?
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing. http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
I'm searching why once I open Geonetwork, nothing work.
I succeed to:
- start the server (a problem with JAI)/
- Open //localhost:8080/geonetwork; but I can't do nothing.
You mean no main page is shown in Geonetwork? Any error page?
The GeoNetwork log seem ok.
I see you installed Geonetwork inside Program Files folder. I would
recommend use a folder outside of Program Files. This folder has special
permissions management by windows and can be problematic to write/update
files in it.
Jose García
GeoCat bv
I succeed to:
I mean, I can open the home page og Geonetwork appears; but if I try to see a
map, or connect with a login or anything else, it fails and write: "the
connexion failed".
