[GeoNetwork-users] Base map Bing Aerial does not work anymore
Hi ! And happy new year to all GN users and devs ! Thnaks for this tool !
Some days ago, the Bing Aerial base map (in map tab) does not work
anymore...
Do you know some thing about this ?
Thanks
*Georges Hinot*
*CNRS - DRIIHM - UMS BBEES (3468)*
Musée d'Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
georges.hinot@anonymised.com
*Tél : 01 40 79 80 44*
*Tél : 06 47 61 84 92*
Le site du LabEx DRIIHM <http://www.driihm.fr/&gt;
Le Géo-catalogue du LabEx DRIIHM
<http://geo-driihm.fr/catalogue/srv/fre/catalog.search#/home&gt;
Hello
Is it back ?
It's working on my instance.
On Thu, Jan 14, 2016 at 11:17 AM, Georges H <georges.hinot@anonymised.com> wrote:
anymore...
Thanks
*Georges Hinot*
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Hi
Yes, thank you. I think yesterday, for few hours, and then re-vanish.
But now it is ok !
2016-01-18 10:19 GMT+01:00 Florent Gravin <florent.gravin@anonymised.com>:
Hello
Is it back ?
anymore...
Thanks
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
*Georges Hinot*
Hi
Sorry, but few days ago, Bing map has re-disappeared...
Do you know anything about this ?
THX
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5247601.html
Nope i will check that soon.
Maybe we need to declare the bing layer differently.
On Wed, Jan 27, 2016 at 3:55 PM, Georgie <georges.hinot@anonymised.com> wrote:
Hi
THX
*camptocamp*
*Florent Gravin*
0479444492
OK thanks in advance !
2016-01-27 15:58 GMT+01:00 Florent gravin-2 [via OSGeo.org] <
ml-node+s1560n5247602h1@anonymised.com>:
On Wed, Jan 27, 2016 at 3:55 PM, Georgie <[hidden email]
<http:///user/SendEmail.jtp?type=node&node=5247602&i=0>> wrote:
> Hi
> THX
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5247602&i=1>
*camptocamp*
*Florent Gravin*
0479444492
[hidden email] <http:///user/SendEmail.jtp?type=node&node=5247602&i=2>
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5247602.html
To unsubscribe from Base map Bing Aerial does not work anymore, click here
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5245304&code=Z2Vvcmdlcy5oaW5vdEBnbWFpbC5jb218NTI0NTMwNHwzMjk4Mzk1Mzk=&gt;
NAML
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html!nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers!nabble%3Aemail.naml-instant_emails!nabble%3Aemail.naml-send_instant_email!nabble%3Aemail.naml&gt;
*Georges Hinot*
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5247612.html
It seems you need a key for bing Map.
The key we had hardcoded in the source may have expired, or they may have
changed their licence policy.
On Wed, Jan 27, 2016 at 4:24 PM, Georgie <georges.hinot@anonymised.com> wrote:
> > Hi
> > THX
> > _______________________________________________
> *camptocamp*
> *Florent Gravin*
> 0479444492
> below:
here
> NAML
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
Hi, ok thanks...
But even if I had a key, I do not see any option in GN to put a Bing map
key. Is there a doc or anything about this ?
And please : Geonetwork above 3.0.0.0 version have other free satellite
base map ?
Thanks
2016-01-28 11:24 GMT+01:00 Florent Gravin <florent.gravin@anonymised.com>:
> > Hi
> > THX
> *camptocamp*
> *Florent Gravin*
> 0479444492
> below:
here
> NAML
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
*Georges Hinot*
You need to put your key here
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/components/common/map/mapService.js#L1413
If it works for you, we probably should set the key in the settings.
On Thu, Jan 28, 2016 at 12:08 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hi, ok thanks...
base map ?
Thanks
> > Hi
> > THX
Performance
> *camptocamp*
> *Florent Gravin*
> 0479444492
discussion
> below:
here
> NAML
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
We fixed this issue.
We added a new default key.
But please put your own key in viewerSettings.bingKey if you have one.
Thanks
On Thu, Jan 28, 2016 at 1:37 PM, Florent Gravin <
wrote:
Hi, ok thanks...
base map ?
Thanks
have changed their licence policy.
> > Hi
> > THX
Performance
> *camptocamp*
> *Florent Gravin*
> 0479444492
discussion
> below:
here
> NAML
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
*Georges Hinot*
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
Hi
Thank you for that, I have just tested, but...
Since I have tested, the choice of base map does not appears in my viewer.
I use GN 3.0.0.0.
I have first change the code like the Git updates specified, then delete the
WEB-INF/data/wro4j-cache.* files, then restart my server.
All run , except base maps ( I have OSM by default, but only, I can not
change to MapQuest or Bing). The field to choice has vanished.
What do you think about ?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5250744.html
Maybe they are gone from your context.
Try to reload the default context from viewer ui.
On Tue, Feb 16, 2016 at 11:06 AM, Georgie <georges.hinot@anonymised.com> wrote:
Hi
I use GN 3.0.0.0.
the
Thanks
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
*camptocamp*
*Florent Gravin*
0479444492
Ouch ! Thanks but I do not know what is it...
Is it a documentation about ?
THX !
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5250886.html
In the map viewer, in the left toolbar click on maps/load default map
On Tue, Feb 16, 2016 at 5:26 PM, Georgie <georges.hinot@anonymised.com> wrote:
THX !
*camptocamp*
*Florent Gravin*
0479444492
right toolbar sorry
On Tue, Feb 16, 2016 at 5:52 PM, Florent Gravin <
THX !
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
Aaah OK... Sorry...
No it does not change. It reset my map, OK.
But the field to choice the base maps is not come back.
I work here :
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5250892.html
i don't understand where your code comes from....
you have javascript errors as well, it should tells you what is wrong.
viewersettings is not injected.
see
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/components/common/map/mapService.js#L40
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/components/common/map/mapService.js#L44
On Tue, Feb 16, 2016 at 5:54 PM, Georgie <georges.hinot@anonymised.com> wrote:
Aaah OK... Sorry...
I work here :
*camptocamp*
*Florent Gravin*
0479444492
OK thanks but I think it is about another version of GN no ? Me I use the
3.0.0.0.
I have changed all the mapService.js file with this Git file, because indeed
I had many difference with the Git file.
But now I have a blank page and others Javascript errors (but more clear I
think...):
Please do you think it is better to come back, or to try impove this ?
Beacause I think my problem is since the change about the call of the Bing
map key (I think).
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5250973.html
Just come back to the release version and hack the bing map key hardcoded
in the mapService.js file.
On Wed, Feb 17, 2016 at 12:43 AM, Georgie <georges.hinot@anonymised.com> wrote:
3.0.0.0.
indeed
think...):
map key (I think).
*camptocamp*
*Florent Gravin*
0479444492
Hi
Many thanks, it run better now !
http://cartoperso.com/geonetwork/srv/fre/catalog.search#/home
See you !
View this message in context: http://osgeo-org.1560.x6.nabble.com/Base-map-Bing-Aerial-does-not-work-anymore-tp5245304p5251712.html
