I'm using "Batch import" to insert many xml files at once (500 files). The
problem is that every time when I import 500 files, for the first time I get
oracle error: ORA-08177 - can't serialize access for this transaction. When
try once more everything is OK. Do you know how to deal with that and what
cause this problem ??
I read about this error and it is caused when transaction isolation level is
set as "serializable" and it is enough to change isolation level on "read
commited". I tried to change it in oracle, wrote trigger on session to set
isolation level but none of this helped. I was looking in geonetwork sources
for possibility to change this but I also didn't found anything. I was even
looking for some information about jeeves because I thought it is defined
there, but I didn't found any documentation.
I would be appreciated for any suggestions.
2007-08-02 14:40:30,638 DEBUG [geonetwork.datamanager] - Extracted UUID
'6940' for schema 'tomek'
2007-08-02 14:40:34,216 ERROR [jeeves.service] - Exception when executing
service
2007-08-02 14:40:34,216 ERROR [jeeves.service] - (C) Exc :
java.sql.SQLException: ORA-08177: can't serialize access for this
transaction
2007-08-02 14:40:34,216 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>ORA-08177: can't serialize access for this transaction</message>
<class>SQLException</class>
<stack>
<at class="oracle.jdbc.driver.DatabaseError" file="DatabaseError.java"
line="125" method="throwSqlException" />
<at class="oracle.jdbc.driver.T4CTTIoer" file="T4CTTIoer.java"
line="305" method="processError" />
line="272" method="processError" />
<at class="oracle.jdbc.driver.T4C8Oall" file="T4C8Oall.java" line="626"
method="receive" />
<at class="oracle.jdbc.driver.T4CPreparedStatement"
file="T4CPreparedStatement.java" line="182" method="doOall8" />
file="T4CPreparedStatement.java" line="630" method="execute_for_rows" />
<at class="oracle.jdbc.driver.OracleStatement"
file="OracleStatement.java" line="961" method="execute_maybe_describe" />
file="T4CPreparedStatement.java" line="532" method="execute_maybe_describe"
file="OracleStatement.java" line="1037" method="doExecuteWithTimeout" />
<at class="oracle.jdbc.driver.OraclePreparedStatement"
file="OraclePreparedStatement.java" line="2905" method="executeInternal" />
</stack>
<request>
<language>en</language>
<service>util.import</service>
</request>
</error>
Łukasz Sobotowski
View this message in context: http://www.nabble.com/batch-import---500-files-at-once-problem-tf4205967s18419.html#a11963961
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Łukasz,
you have to change Jeeves to change the isolation level. Jeeves is always aligned
to the latest version of geonetwork. So, do a svn checkout and change the file:
trunk/src/jeeves/resources/dbms/Dbms.java
service
transaction
executing service
<error id="error">
<stack>
method="receive" />
</stack>
<request>
</request>
</error>
Łukasz Sobotowski
Hi Andrea,
Thank you for your response. I changed the file that you mentioned and now
everything works fine.
Andrea Carboni-2 wrote:
Hi Łukasz,
aligned
file:
The
get
When
what
is
set
sources
even
service
transaction
executing service
<error id="error">
<stack>
line="626"
method="receive" />
</stack>
<request>
</request>
</error>
Łukasz Sobotowski
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/batch-import---500-files-at-once-problem-tf4205967s18419.html#a11996193
