I want to import some iso19115 metadata files into the new geonetwork release.
The batch import works fine,in fact, I get this message after the import
<ok>records:1</ok>
But, when I try to make a search (as administrator) I can't get any result.
However, If I use the "Search for Unused" tool, I can see the imported
metadata.
I've attached the XML and this is my enviroment:
- Geonetwork 2.2.0RC2
- Linux SO
Are there any restriction in order to import iso19115 metadata?
Thanks in advance.
(attachments)
ejemplo.xml (1.32 KB)
