Hello,
I am trying to batch import metadata from my PC running Windows into
GeoNetwork running on a Websphere application server which is running on
Linux. No matter what syntax I try, e.g., using a UNC instead of C:,
trying //, /, \, \\, \/ in the path, or using using a directory on the
Websphere application server (e.g., /opt/data that contains my .xmls) I am
getting the 'directory not found' message, for example:
The requested operation could not be performed.
Exception : Directory not found: C:\data\temp
I don't see any errors in the Websphere logs. I've been able to batch
import when running GeoNetwork on my PC, so I'm wondering if there's
something to do with how GeoNetwork on Linux is handling the path?
Regards, Bob
View this message in context: http://www.nabble.com/Batch-Import-using-remote-directory-tp20247411p20247411.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
