[GeoNetwork-users] batch import
Dear Jean,
tried to do what you suggest: I exported a backup in a zip file from the old geonetwork running instance,
then I set up the new version and I restored the backup renaming my backup.zip in backup.mef.
The procedure went well but unfortunately the categories were not reported.
I don't know where I was wrong...
Any hints would be helpful!
regards
E.
To: geonetwork-users@lists.sourceforge.net
Date: Tue, 4 Nov 2014 12:34:56 +0100
Subject: Re: [GeoNetwork-users] batch import
Did you try an upgrade first ?
(http://geonetwork-opensource.org/manuals/2.10.3/eng/users/quickstartguide/installing/index.html#upgrading-to-a-new-version)
I guess it would be the preferred way...
Apart from that, MEF format (also called the ZIP fomat when doing an
export) supports GN categories, so it should be kept, yes.
I don't know with batch import, but using the Metadata insert menu entry
(if your ZIP file is not too big), it should work. Use the MEF format.
Jean
Dear Jean and all,
as Jean supposed I had something wrong.
I had the category on GN slightly different from those stored in the backup.zip file.
I retrieved the different categories from each info.xml file in the backup (I used 'sed' command),
then I modified the categories in GN pay attention to have the same name (capital letters, spaces, and so on),
eventually I restored the backup ad the categories were maintained.
By the way now I have a new problem on batch import: the problem now is on the file uploaded for each metadata in the
old version of GN. After the restore I'm not able to download the files.
I guess should be a problem on the path, but I'm not sure...
GN store the uploaded file in:
/WEB-INF/data/data/metadata_data/
have I to only copy the old metadata_data dir in the new installation??
I'm afraid not...
Any comments or hints?
Regards
E.
Date: Wed, 5 Nov 2014 15:06:48 +0100
To: frippe12573@anonymised.com
    Hi Eugenion,
    Apparently it went well for Jo (see his last message, same thread),
    so I guess, you had something wrong.
    Is it possible you didn't really re-create the categories identical
    Maybe you should check how they are stored in the MEF file (since
    it's a ZIP, you ca unzip it and explore its content). And try
    exporting something from your new GN instance and check the
    categories exported from this new instance are called the same ?
    Jean
Hi Eugenio,
Normally, the files to download were integrated in the MEF (ZIP) files. Check it.
My guess is the URL has changed, from your old geonetwork instance to the new one (either the webapp name, or the port). When you perform an import, I believe Geonetwork doesn't fix the URL, so it will still try to get the files using the old URL, instead of the new one.
Look at the URL it looks for.
If this is the case, you can directly make the change in the DB, it is often the quickest way. Which DB are you using ?
Jean
Le 10/11/2014 10:46, Eugenio Trumpy a écrit :
Dear Jean and all,
I'm afraid not...
Regards
E.
Hi Eugenion,
Apparently it went well for Jo (see his last message, same thread), so I guess, you had something wrong.
Is it possible you didn't really re-create the categories identical ?
Maybe you should check how they are stored in the MEF file (since it's a ZIP, you ca unzip it and explore its content). And try exporting something from your new GN instance and check the categories exported from this new instance are called the same ?
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Hi Jean,
I checked the MEF (zip) file, but inside there are not any file together with the metadata.
Of course the host name and port has been changed, for instance before in the old GN instance we had name_host:8080 now,
in the new GN we proxed the port so we have only name_host, moreover the name of the app is the same in both istances (i.e., geonetwork).
In the metadata in the old GN I had this link for download data:
http://old_host_name:8080/geonetwork/srv/en/resources.get?id=37222&fname=pozzi_sorgenti_S_Cesarea.zip&access=private
and now I have already modified it with the new host name in:
http://new_host_name/geonetwork/srv/en/resources.get?id=37222&fname=pozzi_sorgenti_S_Cesarea.zip&access=private
What I have noticed is that the file associated with the metadata are stored in /geonetwork/WEB-INF/data/ in the old GN,
but on restoring the backup in the new GN I don't see them in the same dir.
By the way do you know a way to import also the files associated to the metadata?
regards
Eugenio
Date: Tue, 11 Nov 2014 19:53:45 +0100
To: frippe12573@anonymised.com; geonetwork-users@lists.sourceforge.net
    Hi Eugenio,
    files. Check it.
    new one.
    Jean
      écrit :
      Dear Jean and all,
        maintained.
        the files.
        installation??
        I'm afraid not...
        Regards
        E.
          Hi Eugenion,
          identical ?
          called the same ?
          Jean
(attachments)
Dear all,
just to be clear I changed the object of the topic since the main issues on batch import are now solved.
However, as I reported in the last email here below, I have some problems on the files uploaded for each metadata.
The previous situation was: in my old GN I had about 580 metadata and some of them had the related uploaded
zip file. I think GN stores the uploaded file in WEB-INF/data/data/metadata_data but I don't know what happens in the export procedure.
Or does GN store the uploaded file in its mckoi db?
Anyway I exported all the metadata from the old GN and I restored the backup on the new GN.
Of course I changed the URL in the OnLineResources tag of the backuped metadata according to the new name server.
I suspect that the backup of the old GN was not complete, it missed the dir metadata_data where the uploaded zip should be.
What about?
Regards
Eugenio
    Hi Eugenio,
    files. Check it.
    new one.
    Jean
      écrit :
      Dear Jean and all,
        maintained.
        the files.
        installation??
        I'm afraid not...
        Regards
        E.
          Hi Eugenion,
          identical ?
          called the same ?
          Jean
(attachments)
Hi Eugenio,
Yes, GN stores the files in WEB-INF/data/data/metadata_data unless you tell it to place the metadata_data folder somewhere else.
When you export some MEF files, the associated files should be exported with them. If you unzip the MEF archive, you'd find a 'public' folder, that will contain the thumbnail and picture, and a 'private' folder containing you associated files.
Please check that you have the files in this private folder (for metadata that do have associated file, of course)
Is your new instance accessible on internet ? I'd like to check something. As I told you, I would say that the issue is a change in the URL to access the catalog (and thus, to access the files) between your old instance and the new one.
Jean
Le 17/11/2014 10:30, Eugenio Trumpy a écrit :
Dear all,
What about?
Regards
Eugenio
Hi Eugenio,
Jean
    Dear Jean and all,
    files.
    installation??
    I'm afraid not...
    Regards
    E.
    <mailto:jean.pommier@anonymised.com>
    To: frippe12573@anonymised.com <mailto:frippe12573@anonymised.com>
    Hi Eugenion,
    Jean
E-mail : jp@anonymised.com <mailto:jp@anonymised.com>
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
Dear Jean,
starting from the fact tha GN store the uploaded file in WEB-INF/data/data/metadata_data,
I see that in my GN backup (I mean the old GN dir deployed in app server) there is no that directory
but I have only WEB-INF/data/data/removed where there are other subdir containing *.mef file.
On the other hand the backup of the metadata (I made it from the running old GN using 'export' command),
doesn 't contain any file in the 'private' directory.
I guess that's why on restoring the backup on the new GN I have no the resources needed for download.
Could be possible? How could solve this issue?
Regard
Eugenio
Date: Mon, 17 Nov 2014 10:46:43 +0100
Subject: Re: metadata uploaded file on GN migration was: batch import
    Hi Eugenio,
    Jean
      écrit :
      Dear all,
        What about?
        Regards
        Eugenio
Wow, it looks weird. On your old instance, was it still possible to download the data ? Or see the thumbnail ? Are you sure you didn't externalize the geonetwork datadir ? Can you still run the old instance ? First think to check would be that the old instance works properly...
I'm not even sure Geonetwork would start without having a metadata_data folder
If not, it looks like something bad happened.
Le 17/11/2014 12:16, Eugenio Trumpy a écrit :
Dear Jean,
Regard
Eugenio
Hi Eugenio,
Jean
    Dear all,
    What about?
    Regards
    Eugenio
Thank you Jean,
I contacted the Sys Admin of the old GN, just this morning to check the old instance.
I will come back on you tomorrow morning I hope with some answer!
Thanks for now.
E.
Date: Mon, 17 Nov 2014 12:45:38 +0100
    properly...
      écrit :
      Dear Jean,
        Regard
        Eugenio
          import
          Hi Eugenio,
          else.
          Jean
            Trumpy a écrit :
            Dear all,
              metadata.
              should be.
              What about?
              Regards
              Eugenio
Dear Jean and all,
eventually we took a look on the old GN instance, we discovered a data dir outside the GN,
that's why when I made the backup on the old instance in the new server I didn't found
any data related to the metadata (just to be clear: no files there were in the Private directory in
the exported metadata - I mean the file .zip (mef)).
The we migrated the data dir in the new instance of GN (in the new server) and everything went well,
in particular we put the data dir in the default data dir in: WEB-INF/data/data/metadata_data
and it worked fine!
I think everything is now ok, I can say that we made a complete migration from an old version (2.8.x),
to a new 2.10.3 in a new server for all the metadata (581) maintaining the also the correct categories.
Thanks to all
Eugenio
    properly...
      écrit :
      Dear Jean,
        Regard
        Eugenio
          import
          Hi Eugenio,
          else.
          Jean
            Trumpy a écrit :
            Dear all,
              metadata.
              should be.
              What about?
              Regards
              Eugenio
(attachments)
