[GeoNetwork-users] Batch update all records with a SQL query
We are in process with upgrading from GN version 2.4.3 to the new
version 2.10.1.
We run version 2.4.3 in at tomcat 6 with metadata stored in PostgresQL
8.4.3. A new empty database has been created and GN 2.10.1 has
automaticly build a new GN database. All records has been imported via
the MEF format.
A lot of the new records errornously got a "new" parent child relation
created in this process. Checking the exported records the xml file
reveals that the parentIdentifier field contains a "?". We don't
understand why and when this character string has been created.
It is a lot of work to remove the "?" from all records manually.
Will it be possible to make a SQL query to delete this value for all
records in order to make a new export /import without this problem. If
YES how would this query look like.
Poul Toft Laustsen
