I am trying to find out why the following query gets an exception when is
sent to GN (beta2). If anyone can help it would be much appreciated. I am
using the sample data from GAST. The only thing I can think of is that I
might have to add more information in the query. Thanks in advance.
<GetRecords xmlns="http://www.opengis.net/cat/csw"
xmlns:csw="http://www.opengis.net/cat/csw"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml" service="CSW" version="2.0.1"
startPosition="1" maxRecords="10" resultType="results">
<Query>
<Constraint version="1.1.0">
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>ows:BoundingBox</ogc:PropertyName>
<gml:Envelope
srsName="http://www.opengis.net/gml/srs/epsg.xml#63266405">
<gml:lowerCorner>-180 -90</gml:lowerCorner>
<gml:upperCorner>180 90</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</Constraint>
</Query>
</GetRecords>
2007-06-01 08:28:14,512 INFO [jeeves.webapp.csw] - Dispatching operation :
GetRecords
file:///C:/Archivos%20de%20programa/geonetwork-2.1.0-beta1/web/xml/csw/schem
as/fgdc-std/ogc-full.xsl; LÝnea n·m.10; Columna n·m.37; El prefijo debe
resolverse como un espacio de nombres: gmd
as/f
gdc-std/ogc-full.xsl; LÝnea n·m.10; Columna n·m.37; íExpresi¾n vacÝa!
as/fgdc-std/ogc-full.xsl; LÝnea n·m.10; Columna n·m.37; Se esperaba un
patr¾n de vÝa de acceso relativa.
(Ubicaci¾n del error desconocida)java.lang.NullPointerException
2007-06-01 08:28:14,653 ERROR [jeeves.webapp.csw] - Error while getting
metadata with id : 6
2007-06-01 08:28:14,653 ERROR [jeeves.webapp.csw] - (C) StackTrace:
at jeeves.utils.Xml.transform(Xml.java:136)
at jeeves.utils.Xml.transform(Xml.java:114)
at
org.fao.geonet.kernel.csw.services.getrecords.SearchController.retrie
veMetadata(SearchController.java:127)
at
org.fao.geonet.kernel.csw.services.getrecords.SearchController.search
(SearchController.java:73)
at
org.fao.geonet.kernel.csw.services.GetRecords.execute(GetRecords.java
:107)
at
org.fao.geonet.kernel.csw.CatalogDispatcher.dispatchI(CatalogDispatch
er.java:170)
at
org.fao.geonet.kernel.csw.CatalogDispatcher.dispatch(CatalogDispatche
r.java:117)
at
org.fao.geonet.services.main.CswDispatcher.exec(CswDispatcher.java:55
at
jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:22
6)
at
jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:1
29)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java
:370)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:600)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:1
63)
at
jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:427
at
org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicati
onHandler.java:473)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:5
68)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1565)
at
org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplication
Context.java:635)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1517)
at org.mortbay.http.HttpServer.service(HttpServer.java:954)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:816)
at
org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:983)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:833)
at
org.mortbay.http.SocketListener.handleConnection(SocketListener.java:
244)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)
