here is a quick new beta which fixes some annoying bugs.
There are also some new features:
- Added possibility to harvest old geonetwork 2.0 nodes
- Passwords are now encrypted using a SHA-1 algorithm
Due to this release and some delays, the RC release will
be postponed by 1 week.
hi! i'm new to this forum. i just downloaded the beta 3 version and i tried
to import some xml code which i created recently and i made sure it was
valid. i saved this file to my harddrive as an xml file and then tried to
upload it using the xml metadata insert feature.
i selected iso 19115 for schema and then clicked insert. i saw all the
fields being filled in correctly except now when i click the check button on
top, i get the following errors
Cannot build ServiceRequest
Cause : C:\Program Files\geonetwork\web\WEB-INF\data\tmp (Access is denied)
Error : java.io.FileNotFoundException
Stack :
java.io.FileNotFoundException: C:\Program
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at
org.apache.commons.fileupload.disk.DiskFileItem.write(DiskFileItem.java:400)
at
jeeves.server.sources.ServiceRequestFactory.getMultipartParams(ServiceRequestFactory.java:265)
at
jeeves.server.sources.ServiceRequestFactory.extractParameters(ServiceRequestFactory.java:214)
at
jeeves.server.sources.ServiceRequestFactory.create(ServiceRequestFactory.java:136)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:146)
at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:427)
at
org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:473)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1565)
at
org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:635)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1517)
at org.mortbay.http.HttpServer.service(HttpServer.java:954)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:816)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:983)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:833)
at
org.mortbay.http.SocketListener.handleConnection(SocketListener.java:244)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)
RequestURI=/geonetwork/srv/en/metadata.update.validate
can anyone help?
Andrea Carboni-2 wrote:
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Beta-3-available-tf3878482s18419.html#a11233167
Sent from the geonetwork-users mailing list archive at Nabble.com.
