Hello.
I noticed there are active bugs on both sourceforge and <http://trac.osgeo.org/geonetwork/>\. Is the trac site the one to use? Can the sourceforge ones be migrated/closed if so?
When I look at all bugs by milestone, I notice that there is a v2.1 beta 1, v2.1 beta 2, v2.1 RC1, and v2.1 RC2. Is there some way to tell what was fixed between beta 2 and beta 4? Is there a more recent release of 2.1 somewhere?
When I try to create a new ticket, I get "TICKET_CREATE privileges are required to perform this operation". How do I obtain permission to file a bug? Can this be opened up or are there spambot problems?
I had begun doing a fresh complete install of beta 4 on RedHat Enterprise Linux v4 using Java 6 and Postgres 8.2.4 and was planning to create tickets for all problems along the way, plus attach patches for anything I could resolve on my own. Is this a useful exercise or are you aware of the problems and they just haven't been fixed yet?
The only tickets I could find that look relevant to me are:
"#5 Setup on Postgresql fails with type error" which has been closed and marked "worksforme" but doesn't list the version that "works" and also suggests that there is a problem in the code... but the bug isn't marked fixed so I don't know what's going on. When I tried beta 2, I had this problem.
"#22 Getting the list of latest updated entries: Postgres complains" which appears open and may explain a postgres complaint, but I can't tell which one from the description.
"#20 Scrambled passwords don't fit database" which seems to be the varchar(32) too small problem. If I understand the trac "Milestone" field correctly, it should have been fixed in beta 2, but is still open. I still saw this problem in beta 2 and I believe others are seeing it in beta 4.
I don't see any open issues for:
- ERROR: the column "operationid" is integer type but the expression is varying char type
- Cyclic reference found: [Metadata, Relations, ...]
- Server should have command line install option and/or documentation for headless servers
I hope this helps. Please let me know how I should proceed. I can't jump into the code, but I'm willing to file bugs and document workarounds if it looks like the effort will make a difference.
Amos Hayes
Geomatics and Cartographic Research Centre
Carleton University
ahayes@anonymised.com
+1.613.520.2600x8179
On 23-Jul-07, at 9:48 AM, Amos Hayes wrote:
I've had all the same problems you describe with beta 2; however,
when I loaded the tables via the script, I was still unable to log in
with the admin user.
I am going to try Beta 4 (the website is out of date... but I found
the latest in the sourceforge listings) but it sounds like I
shouldn't hold out much hope. I'll file bugs for all these problems
and use something else for the time being. If anyone is able to get
geonetwork working with Postgres, please post all the changes you
made so I can replicate and submit patches (or submit them yourself
if able.)
Amos Hayes
Carleton University
On 23-Jul-07, at 3:41 AM, José Vicente Higón wrote:
Thanks for your answers,
I modified the "create-db-postgres.sql" script and I could connect to
geonetwork with the user admin. However other errors occured like :
"ERROR: the column "operationid" is integer type but the expression
is varying
char type". Then I could connect but when I wanted to create a new
metadata
the field "template" was empty.
I think you are right, at the moment the solution is to insert the
data
manually. I connected to the database with Druid but I don't know
how can I
load the data from DDF files, can you help me, please?
Hi Jose
Apologies for the late response.
Am also using geonetwork 2.1.0 beta 4 with Ubuntu 7.04, postgres 8.2
and Tomcat 5.5.
Have experienced both issues, the cyclic reference issue existed last
time I created a database from scratch.
A possible work around that works for me, is to connect to database
using "Database Druid" and load each table separately, with data from
the "xxx/geonetwork/gast/setup/db" directory.
This should allow you to log on as "admin", however I still
experience
issues when adding users who are not administrators.
Regards
Brian
Subject:
[GeoNetwork-users] Beta4 release and postgres
José Vicente Higón <josevicente.higon@anonymised.com>
Date:
Tue, 17 Jul 2007 09:50:23 +0200
To:
geonetwork-users@lists.sourceforge.net
I've tried to install geonetwork 2.1.0 beta4 using postgres as
backend.
First of all I installed geonetwork with the database embedded and it
worked fine. Secondly I ran gast to change the database but
several errors
(messages) occured:
1. Cyclic reference found: [Metadata, Relations, ...]
2. ERROR: the value is too long for the type character varying(32)
The web application works fine despite these errors, but I
couldn't log in.
I saw the table called "Users" was empty and I tried to insert a
record
into it but I haven't be able to login yet.
Any clue?
I'm using postgres 8.1 in kubuntu feisty, with a database with
encoding
UTF-8.
Thanks in advance.
-- José Vicente Higón Valero Grupo desarrollo gvSIG. IVER TI S.A.
C/Salamanca, 50-52 46005-Valencia Tlf.+34963163400 http://www.iver.es
http://www.gvsig.com http://www.gvsig.gva.es
Now Search log events and configuration files using AJAX and a
browser.
GeoNetwork-users mailing list
IVER TI S.A.
Tlf.+34963163400
http://www.iver.es
browser.
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
