[GeoNetwork-users] binding to LDAP [Sec=Unclassified]
I'm trying to bind to Active directory ldap but the configuration options don't give me the option to specify a bind user. Many LDAP systems are not accessible anonymously and hence a user with special privileges needs to be used to bind to the server before a query can be made such as authenticating a user.
I guess geonetwork attempts to bind with the users username/password but that is insufficient in this case. Is there a way that I can set the bind username/password somehow?
Miles Jordan, Systems Analyst
Australian Antarctic Data Centre | Australian Antarctic Division
Dept. for Sustainability, Environment, Water, Population and Communities
http://data.aad.gov.au
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.antarctica.gov.au/
