[GeoNetwork-users] Broken file download
Hi Users
My previous post - cant create record is linked to using the Chrome browser, I have tested using IE and using FireFox and both of these browsers work. Even a direct XML copy in raw mode using chrome did not work.
But I have moved on for now, and I created a metadata record, which has a file associated with it.
http://auscope-portal-dev.arrc.csiro.au/geonetwork/srv/en/metadata.show?id=56566
however the link that geonetwork produces is
http://localhost:8080/geonetwork/srv/en/resources.get?id=56566&fname=LatrobeValley_with3D.pdf&access=private
which is not right, and I can't edit it either, any change I make to that box is lost by the interface, and the previous value comes back.
I am also presented with a broken remove button as attached.
What do I need to do to fix the rendering and the URL location?
Terry
(attachments)
Hi Terry
I think this is caused by the Server configuration in "System configuration"
parameters, probably contains default configuration (localhost, 8080).
You need to change Host to auscope-portal-dev.arrc.csiro.au and Port to 80.
This should solve at least the problem for new metadata you create with
associated files.
For existing metadata, i hope editing and saving the metadata (after
previous change), the URL link will be updated with new server config.
Jose Garcia
On Thu, Sep 16, 2010 at 8:21 AM, <Terry.Rankine@anonymised.com> wrote:
Hi Users
Terry
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
GeoNetwork-users mailing list
Hi Terry,
Maybe be that your server host and port in System->Admin Config
are set to localhost and port 8080.
Go to System->Admin Config page and try changing these to auscope-portal-dev.arrc.csiro.au
and port 80 respectively.
HTH
Andrew
----- Original Message ----- From: <Terry.Rankine@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Thursday, September 16, 2010 16:21
Subject: [GeoNetwork-users] Broken file download
Hi Users
Terry
Ahh - Your both right.
Thanks guys
I was under the assumption that the little things like server config had been done.... looks like I was wrong.
I have done a DB level search and no other records are currently using the repository function on that instance.
Any ideas about the 'remove button' for that file record? Its broken on both FF and IE browsers.
Terry Rankine
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: Thursday, 16 September 2010 2:49 PM
To: Rankine, Terry (CESRE, Kensington)
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Broken file download
Hi Terry
I think this is caused by the Server configuration in "System configuration" parameters, probably contains default configuration (localhost, 8080).
This should solve at least the problem for new metadata you create with associated files.
For existing metadata, i hope editing and saving the metadata (after previous change), the URL link will be updated with new server config.
Jose Garcia
Hi Users
Terry
Hi Terry,
Beyond changing that setting, you could then fix the metadata URLs using GAST. GAST is a desktop administration tool for GeoNetwork that was also installed with GeoNetwork. Please refer to the manual to understand how to do this. After configuring the connection in GAST run the Metadata sync task.
Jeroen
____________________________________________________
Dutch National georegistry nominated as government ICT-project of the year!
Readers of Computable (a recognized ICT website in The Netherlands) have nominated the National Georegistry as government ICT project of the year.
Please vote before 23 September 2010 at: http://www2.computable.nl/computableawards/stem/
GeoCat implemented the National Georegistry on the basis of GeoNetwork opensource
Jeroen Ticheler
GeoCat bv
Irisstraat 52
7531 CW Enschede
Tel: +31 (0)6 81286572
Please consider the environment before printing this email.
On 16 sep 2010, at 08:49, jose garcia wrote:
Hi Terry
associated files.
Jose Garcia
Hi Users
Terry
hello Terry,
in my opinion it is a usability bug that an element appears to be an
editable input field, but if you change it, you're change isn't saved.
Should we create a bug report in trac for it ?
Kind regards
Heikki Doeleman
On Thu, Sep 16, 2010 at 8:58 AM, Jeroen Ticheler <jeroen.ticheler@anonymised.com
wrote:
Hi Terry,
task.
Jeroen
opensource
Jeroen Ticheler
GeoCat bv
Irisstraat 52
7531 CW Enschede
http://geocat.net
> Hi Terry
configuration"
80.
> associated files.
> Regards,
> Jose Garcia
>> Hi Users
browsers
a
that
>> Terry
I think so – even a tool tip that tells you this is a GeoNetwork Managed feild or something like that.
And the other render bug which is the remove button is broken
Terry Rankine
Sent: Thursday, 16 September 2010 3:56 PM
To: Jeroen Ticheler
Cc: Rankine, Terry (CESRE, Kensington); Users geonetwork-users
hello Terry,
in my opinion it is a usability bug that an element appears to be an editable input field, but if you change it, you're change isn't saved.
Kind regards
Heikki Doeleman
On Thu, Sep 16, 2010 at 8:58 AM, Jeroen Ticheler <jeroen.ticheler@...444...<mailto:jeroen.ticheler@…444…>> wrote:
Hi Terry,
Jeroen
Jeroen Ticheler
GeoCat bv
Irisstraat 52
7531 CW Enschede
http://geocat.net
Hi Terry
You need to change Host to auscope-portal-dev.arrc.csiro.au<http://auscope-portal-dev.arrc.csiro.au> and Port to 80.
associated files.
Jose Garcia
On Thu, Sep 16, 2010 at 8:21 AM, <Terry.Rankine@...448...> wrote:
Hi Users
Terry
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
