[GeoNetwork-users] bug with massive ownership transfer ?
I get an error message when trying to perform massive ownership transfer :
PSQLException : ERREUR: la colonne � owner � est de type integer mais
l'expression est de type character varying
[in english : the column 'owner' is of type Integer, but the expression is
of type character varying]
I'm using postgreSQL.
It looks like it comes from geonet/kernel/DataManager.java : changing the
owner and gourpOwner type to integer resvoles it :
    public synchronized void updateMetadataOwner(UserSession session, Dbms
dbms, int id, String owner, String groupOwner) throws Exception
        dbms.execute("UPDATE Metadata SET owner=?, groupOwner=? WHERE id=?",
*new Integer(owner), new Integer(groupOwner)*, id);
Jean
