[GeoNetwork-users] bugs? in geonetwork243 (build from svn)
hello,
found following problems when using geonetwork243:
1. add harvest node csw2.0.2 ap iso: add priveleges:
javascript alerts:
a) ReferenceError: Sarissa is not defined
b) function update_OK(node) {
    if (view.isAdding()) {
        view.append(node);
    } else {
        view.refresh(node);
    view.show(SHOW.LIST);
2. administration/system configuration
no inspire checkbox?
hope that helps
regards
armin
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
Hi Armin
I have to check about harvesting.
About the setting for INSPIRE, is not in system configuration (I think
there's later post in the list with this). For now is defined in the file
web\geonetwork\WEB-INF\config-gui.xml. You should change the inspire
parameter from 0 to value 1 to enable INSPIRE and restart geonetwork.
Jose Garcia
2010/4/27 Armin Retterath <armin.retterath@anonymised.com>
hello,
javascript alerts:
       view.append(node);
   } else {
       view.refresh(node);
hope that helps
regards
armin
Im Auftrag
Armin Retterath
beim
56073 Koblenz
GeoNetwork-users mailing list
