[GeoNetwork-users] building geonetwork fail [INFO] GeoNetwork common utils ........................... FAILURE
I'm trying to create .war file from the source using maven but I'm getting this error:
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource ............................. SUCCESS [3:36.289s]
[INFO] GeoNetwork common utils ........................... FAILURE [2:03.848s]
[INFO] Caching xslt module ............................... SKIPPED
[INFO] ArcSDE module (dummy-api) ......................... SKIPPED
[INFO] GeoNetwork domain ................................. SKIPPED
[INFO] Oaipmh modules .................................... SKIPPED
[INFO] GeoNetwork Events ................................. SKIPPED
[INFO] GeoNetwork schema plugins ......................... SKIPPED
[INFO] GeoNetwork schema plugins core .................... SKIPPED
[INFO] GeoNetwork schema plugin for ISO19139/119 standards SKIPPED
[INFO] Index module ...................................... SKIPPED
[INFO] GeoNetwork core ................................... SKIPPED
[INFO] GeoNetwork schema plugin for Dublin Core records retrieved by CSW SKIPPED
[INFO] GeoNetwork schema plugin for Dublin Core standard . SKIPPED
[INFO] GeoNetwork schema plugin for ISO19110 standard .... SKIPPED
[INFO] GeoNetwork schema plugin for ISO19115-3:2018 standard SKIPPED
[INFO] GeoNetwork CSW server ............................. SKIPPED
[INFO] GeoNetwork harvesters ............................. SKIPPED
[INFO] GeoNetwork health monitor ......................... SKIPPED
[INFO] GeoNetwork Digital Object Identifier (DOI) client . SKIPPED
[INFO] GeoNetwork services ............................... SKIPPED
[INFO] Geonetwork Web Resources 4 Java ................... SKIPPED
[INFO] GeoNetwork INSPIRE Atom ........................... SKIPPED
[INFO] GeoNetwork index using Elasticsearch .............. SKIPPED
[INFO] GeoNetwork dashboard app based on Kibana .......... SKIPPED
[INFO] Release module .................................... SKIPPED
[INFO] gn-messaging ...................................... SKIPPED
[INFO] gn-workers ........................................ SKIPPED
[INFO] WFS features harvester ............................ SKIPPED
[INFO] gn-camelPeriodicProducer .......................... SKIPPED
[INFO] gn-es-test ........................................ SKIPPED
[INFO] GeoNetwork Slave .................................. SKIPPED
[INFO] Tests for schema plugins .......................... SKIPPED
[INFO] GeoNetwork user interface module .................. SKIPPED
[INFO] GeoNetwork Web module ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:40.515s
[INFO] Finished at: Thu Sep 30 09:32:48 UTC 2021
[INFO] Final Memory: 18M/295M
[ERROR] Failed to execute goal on project gn-common: Could not resolve dependencies for project org.geonetwork-opensource:gn-common:jar:4.0.6-SNAPSHOT: Failed to collect dependencies for [org.jdom:jdom:jar:1.1.2 (compile), jdbm:jdbm:jar:1.0 (compile), log4j:log4j:jar:1.2.17 (compile), org.apache.jcs:jcs:jar:1.3 (compile), net.sf.saxon:saxon:jar:9.1.0.8b-patch (compile), globus:cog-jglobus:jar:1.2-060802 (compile), xerces:xercesImpl:jar:2.12.0 (compile), xml-resolver:xml-resolver-patched:jar:1.2.1 (compile), jaxen:jaxen:jar:1.1.4 (compile), jsch:jsch:jar:0.1.8 (compile), commons-io:commons-io:jar:2.7 (compile), com.google.guava:guava:jar:29.0-jre (compile), org.quartz-scheduler:quartz:jar:2.3.2 (compile), org.apache.xmlgraphics:fop:jar:2.4 (compile), commons-lang:commons-lang:jar:2.6 (compile), org.apache.httpcomponents:httpclient:jar:4.5.9 (compile), com.googlecode.juniversalchardet:juniversalchardet:jar:1.0.3 (compile), org.springframework:spring-web:jar:5.2.6.RELEASE (compile), org.springframework:spring-context:jar:5.2.6.RELEASE (compile), org.springframework:spring-test:jar:5.2.6.RELEASE (compile), org.eclipse.core:org.eclipse.core.runtime:jar:3.7.0 (compile), net.sf.json-lib:json-lib:jar:jdk15:2.4 (compile), xom:xom:jar:1.1 (compile), com.fasterxml.jackson.core:jackson-databind:jar:2.10.4 (compile), org.json:json:jar:20140107 (compile), com.google.code.findbugs:jsr305:jar:2.0.1 (compile), junit:junit:jar:4.13.1 (test), com.google.jimfs:jimfs:jar:1.0 (test)]: Failed to read artifact descriptor for net.sf.saxon:saxon:jar:9.1.0.8b-patch: Could not transfer artifact net.sf.saxon:saxon:pom:9.1.0.8b-patch from/to osgeo (https://repo.osgeo.org/repository/release/): hostname in certificate didn't match: <repo.osgeo.org> != <docker.osgeo.org> OR <docker.osgeo.org> OR <geos-docker.osgeo.org> OR <geoserver-docker.osgeo.org> OR <postgis-docker.osgeo.org> -> [Help 1]
I followed the usual instruction to create it:
git clone --recursive https://github.com/geonetwork/core-geonetwork.git
cd core-geonetwork
mvn clean install -DskipTests
This error appears both using the latest version and using my repo for the 3.11 version.
Any helps would be appreciated.
Thanks.
Bartolomeo
Bartolomeo Ventura, PhD
Eurac Research
Institute for Earth Observation
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/&gt;
It seems a problem with the osgeo.org artifacts repository:
It seems fixed now, probably a temporary server condition. I'd suggest you
to try again.
On Thu, Sep 30, 2021 at 2:12 PM Ventura Bartolomeo via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
this error:
[INFO]
[3:36.289s]
[2:03.848s]
SKIPPED
[INFO]
[INFO]
[INFO]
cd core-geonetwork
3.11 version.
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Juan,
Thanks for your email but I just tried and I got the same error.
Scarica Outlook per Android<https://aka.ms/AAb9ysg&gt;
From: Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com>
Sent: Thursday, September 30, 2021 5:00:01 PM
To: Ventura Bartolomeo <bartolomeo.ventura@anonymised.com>
Cc: Geonetwork-Users@anonymised.com <geonetwork-users@lists.sourceforge.net>
Subject: Re: [GeoNetwork-users] building geonetwork fail [INFO] GeoNetwork common utils ........................... FAILURE
It seems a problem with the osgeo.org<http://osgeo.org> artifacts repository:
Could not transfer artifact net.sf.saxon:saxon:pom:9.1.0.8b-patch from/to osgeo (https://repo.osgeo.org/repository/release/): hostname in certificate didn't match: <repo.osgeo.org<http://repo.osgeo.org/&gt;&gt; != <docker.osgeo.org<http://docker.osgeo.org/&gt;&gt; OR <docker.osgeo.org<http://docker.osgeo.org/&gt;&gt; OR <geos-docker.osgeo.org<http://geos-docker.osgeo.org/&gt;&gt; OR <geoserver-docker.osgeo.org<http://geoserver-docker.osgeo.org/&gt;&gt; OR <postgis-docker.osgeo.org<http://postgis-docker.osgeo.org/&gt;&gt; -
It seems fixed now, probably a temporary server condition. I'd suggest you to try again.
On Thu, Sep 30, 2021 at 2:12 PM Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comrge.net>> wrote:
[INFO]
[ERROR] Failed to execute goal on project gn-common: Could not resolve dependencies for project org.geonetwork-opensource:gn-common:jar:4.0.6-SNAPSHOT: Failed to collect dependencies for [org.jdom:jdom:jar:1.1.2 (compile), jdbm:jdbm:jar:1.0 (compile), log4j:log4j:jar:1.2.17 (compile), org.apache.jcs:jcs:jar:1.3 (compile), net.sf.saxon:saxon:jar:9.1.0.8b-patch (compile), globus:cog-jglobus:jar:1.2-060802 (compile), xerces:xercesImpl:jar:2.12.0 (compile), xml-resolver:xml-resolver-patched:jar:1.2.1 (compile), jaxen:jaxen:jar:1.1.4 (compile), jsch:jsch:jar:0.1.8 (compile), commons-io:commons-io:jar:2.7 (compile), com.google.guava:guava:jar:29.0-jre (compile), org.quartz-scheduler:quartz:jar:2.3.2 (compile), org.apache.xmlgraphics:fop:jar:2.4 (compile), commons-lang:commons-lang:jar:2.6 (compile), org.apache.httpcomponents:httpclient:jar:4.5.9 (compile), com.googlecode.juniversalchardet:juniversalchardet:jar:1.0.3 (compile), org.springframework:spring-web:jar:5.2.6.RELEASE (compile), org.springframework:spring-context:jar:5.2.6.RELEASE (compile), org.springframework:spring-test:jar:5.2.6.RELEASE (compile), org.eclipse.core:org.eclipse.core.runtime:jar:3.7.0 (compile), net.sf.json-lib:json-lib:jar:jdk15:2.4 (compile), xom:xom:jar:1.1 (compile), com.fasterxml.jackson.core:jackson-databind:jar:2.10.4 (compile), org.json:json:jar:20140107 (compile), com.google.code.findbugs:jsr305:jar:2.0.1 (compile), junit:junit:jar:4.13.1 (test), com.google.jimfs:jimfs:jar:1.0 (test)]: Failed to read artifact descriptor for net.sf.saxon:saxon:jar:9.1.0.8b-patch: Could not transfer artifact net.sf.saxon:saxon:pom:9.1.0.8b-patch from/to osgeo (https://repo.osgeo.org/repository/release/): hostname in certificate didn't match: <repo.osgeo.org<http://repo.osgeo.org>> != <docker.osgeo.org<http://docker.osgeo.org>> OR <docker.osgeo.org<http://docker.osgeo.org>> OR <geos-docker.osgeo.org<http://geos-docker.osgeo.org>> OR <geoserver-docker.osgeo.org<http://geoserver-docker.osgeo.org>> OR <postgis-docker.osgeo.org<http://postgis-docker.osgeo.org>> -> [Help 1]
cd core-geonetwork
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com><mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu><http://www.eurac.edu/&gt;
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
[https://www.geocat.net/wp-content/uploads/2015/07/GeoCat_small1.png\]<http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664<tel:+31318416664>
Please consider the environment before printing this email.
I've tried to follow exactly your steps in the `main` branch and the
process has finished successfully (Maven 3.8.2 and an empty .m2 folder):
INFO] GeoNetwork opensource .............................. SUCCESS [01:10
min]
[INFO] GeoNetwork common utils ............................ SUCCESS [02:08
min]
[INFO] Caching xslt module ................................ SUCCESS [
0.193 s]
[INFO] ArcSDE module (dummy-api) .......................... SUCCESS [
0.182 s]
[INFO] GeoNetwork domain .................................. SUCCESS [01:08
min]
[INFO] Oaipmh modules ..................................... SUCCESS [
0.308 s]
[INFO] GeoNetwork Events .................................. SUCCESS [
0.234 s]
[INFO] GeoNetwork schema plugins .......................... SUCCESS [
0.011 s]
[INFO] GeoNetwork schema plugins core ..................... SUCCESS [
3.568 s]
[INFO] GeoNetwork schema plugin for ISO19139/119 standards SUCCESS [
11.246 s]
[INFO] Index module ....................................... SUCCESS [
27.643 s]
[INFO] GeoNetwork core .................................... SUCCESS [03:40
min]
0.753 s]
SUCCESS [ 0.135 s]
[INFO] GeoNetwork schema plugin for Dublin Core standard .. SUCCESS [
0.249 s]
[INFO] GeoNetwork schema plugin for ISO19110 standard ..... SUCCESS [
0.217 s]
[INFO] GeoNetwork schema plugin for ISO19115-3:2018 standard SUCCESS [
33.035 s]
[INFO] GeoNetwork CSW server .............................. SUCCESS [
6.025 s]
[INFO] GeoNetwork harvesters .............................. SUCCESS [
6.789 s]
[INFO] GeoNetwork health monitor .......................... SUCCESS [
0.983 s]
[INFO] GeoNetwork Digital Object Identifier (DOI) client .. SUCCESS [
0.703 s]
[INFO] GeoNetwork services ................................ SUCCESS [
52.606 s]
[INFO] Geonetwork Web Resources 4 Java .................... SUCCESS [01:03
min]
[INFO] GeoNetwork INSPIRE Atom ............................ SUCCESS [
3.533 s]
[INFO] GeoNetwork index using Elasticsearch ............... SUCCESS [
0.004 s]
[INFO] GeoNetwork dashboard app based on Kibana ........... SUCCESS [
0.028 s]
[INFO] Release module ..................................... SUCCESS [
0.019 s]
[INFO] gn-messaging ....................................... SUCCESS [
29.861 s]
[INFO] gn-workers ......................................... SUCCESS [
0.009 s]
[INFO] WFS features harvester ............................. SUCCESS [
43.886 s]
[INFO] gn-camelPeriodicProducer ........................... SUCCESS [
6.141 s]
[INFO] gn-es-test ......................................... SUCCESS [
1.350 s]
[INFO] GeoNetwork Slave ................................... SUCCESS [
0.558 s]
[INFO] Tests for schema plugins ........................... SUCCESS [
0.808 s]
[INFO] GeoNetwork user interface module ................... SUCCESS [
7.122 s]
[INFO] GeoNetwork Web module .............................. SUCCESS [01:59
min]
[INFO]
[INFO] BUILD SUCCESS
[INFO]
[INFO] Total time: 15:08 min
[INFO] Finished at: 2021-10-01T08:23:00Z
[INFO]
Do you have any mirror set in .m2/settings.xml? Can you rename your .m2
folder and try again?
On Fri, Oct 1, 2021 at 8:03 AM Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> wrote:
Hi Juan,
Scarica Outlook per Android <https://aka.ms/AAb9ysg&gt;
*From:* Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com>
*Sent:* Thursday, September 30, 2021 5:00:01 PM
*To:* Ventura Bartolomeo <bartolomeo.ventura@anonymised.com>
*Cc:* Geonetwork-Users@anonymised.com <
*Subject:* Re: [GeoNetwork-users] building geonetwork fail [INFO]
to try again.
this error:
[INFO]
[3:36.289s]
[2:03.848s]
SKIPPED
[INFO]
[INFO]
[INFO]
cd core-geonetwork
3.11 version.
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
* Vriendelijke groeten / Kind regards, Juan Luis Rodríguez.
<http://www.geocat.net/&gt; Veenderweg 13 6721 WD Bennekom The Netherlands
T: +31 (0)318 416664 <+31318416664> Please consider the environment before
printing this email. *
this email.*
Which version of Java are you using?
Byron Cochrane
OpenWork
Sent from my iPhone
On 1/10/2021, at 8:41 PM, Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote:
Hi Juan,
On Thu, Sep 30, 2021 at 2:12 PM Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comforge.net>> wrote:
[INFO]
cd core-geonetwork
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comceforge.net>
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Byron,
This is the output of java -version cmd
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
Bartolomeo
-----Original Message-----
Sent: Friday, October 1, 2021 10:37
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Cc: Juan Luis Rodríguez Ponce <juanluisrp@...444...>; geonetwork-users@lists.sourceforge.net
Byron Cochrane
OpenWork
Sent from my iPhone
Hi Juan,
From: Juan Luis Rodríguez Ponce <juanluisrp@...444...>
Cc: Geonetwork-Users@...638...
On Thu, Sep 30, 2021 at 2:12 PM Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>> wrote:
[INFO]
[3:36.289s] [INFO] GeoNetwork common utils ...........................
FAILURE [2:03.848s] [INFO] Caching xslt module
............................... SKIPPED [INFO] ArcSDE module
(dummy-api) ......................... SKIPPED [INFO] GeoNetwork domain
................................. SKIPPED [INFO] Oaipmh modules
.................................... SKIPPED [INFO] GeoNetwork Events
................................. SKIPPED [INFO] GeoNetwork schema
plugins ......................... SKIPPED [INFO] GeoNetwork schema
plugins core .................... SKIPPED [INFO] GeoNetwork schema
plugin for ISO19139/119 standards SKIPPED [INFO] Index module
...................................... SKIPPED [INFO] GeoNetwork core
plugin for Dublin Core records retrieved by CSW SKIPPED [INFO]
GeoNetwork schema plugin for Dublin Core standard . SKIPPED [INFO]
GeoNetwork schema plugin for ISO19110 standard .... SKIPPED [INFO]
GeoNetwork schema plugin for ISO19115-3:2018 standard SKIPPED [INFO]
GeoNetwork CSW server ............................. SKIPPED [INFO]
GeoNetwork harvesters ............................. SKIPPED [INFO]
GeoNetwork health monitor ......................... SKIPPED [INFO]
GeoNetwork Digital Object Identifier (DOI) client . SKIPPED [INFO]
GeoNetwork services ............................... SKIPPED [INFO]
Geonetwork Web Resources 4 Java ................... SKIPPED [INFO]
GeoNetwork INSPIRE Atom ........................... SKIPPED [INFO]
GeoNetwork index using Elasticsearch .............. SKIPPED [INFO]
GeoNetwork dashboard app based on Kibana .......... SKIPPED [INFO]
Release module .................................... SKIPPED [INFO]
gn-messaging ...................................... SKIPPED [INFO]
gn-workers ........................................ SKIPPED [INFO] WFS
features harvester ............................ SKIPPED [INFO]
gn-camelPeriodicProducer .......................... SKIPPED [INFO]
gn-es-test ........................................ SKIPPED [INFO]
GeoNetwork Slave .................................. SKIPPED [INFO]
Tests for schema plugins .......................... SKIPPED [INFO]
GeoNetwork user interface module .................. SKIPPED [INFO]
GeoNetwork Web module ............................. SKIPPED [INFO]
[INFO]
[INFO] Finished at: Thu Sep 30 09:32:48 UTC 2021 [INFO] Final Memory:
18M/295M [INFO]
-- [ERROR] Failed to execute goal on project gn-common: Could not
1]
cd core-geonetwork
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…><mail
to:bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>>
Viale Druso 1
I-39100 Bolzano
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@…187…
ourceforge.net>
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Juan,
I have this version of maven
mvn -version
Apache Maven 3.0.5 (Red Hat 3.0.5-17)
I renamed the folder .m2 but I got the same error again
Should I update maven to the same version you have?
Thanks
Bartolomeo
Sent: Friday, October 1, 2021 10:31
I've tried to follow exactly your steps in the `main` branch and the process has finished successfully (Maven 3.8.2 and an empty .m2 folder):
INFO] GeoNetwork opensource .............................. SUCCESS [01:10 min]
[INFO] GeoNetwork common utils ............................ SUCCESS [02:08 min]
[INFO] Caching xslt module ................................ SUCCESS [ 0.193 s]
[INFO] ArcSDE module (dummy-api) .......................... SUCCESS [ 0.182 s]
[INFO] GeoNetwork domain .................................. SUCCESS [01:08 min]
[INFO] Oaipmh modules ..................................... SUCCESS [ 0.308 s]
[INFO] GeoNetwork Events .................................. SUCCESS [ 0.234 s]
[INFO] GeoNetwork schema plugins .......................... SUCCESS [ 0.011 s]
[INFO] GeoNetwork schema plugins core ..................... SUCCESS [ 3.568 s]
[INFO] GeoNetwork schema plugin for ISO19139/119 standards SUCCESS [ 11.246 s]
[INFO] Index module ....................................... SUCCESS [ 27.643 s]
[INFO] GeoNetwork core .................................... SUCCESS [03:40 min]
[INFO] GeoNetwork Events .................................. SUCCESS [ 0.753 s]
[INFO] GeoNetwork schema plugin for Dublin Core records retrieved by CSW SUCCESS [ 0.135 s]
[INFO] GeoNetwork schema plugin for Dublin Core standard .. SUCCESS [ 0.249 s]
[INFO] GeoNetwork schema plugin for ISO19110 standard ..... SUCCESS [ 0.217 s]
[INFO] GeoNetwork schema plugin for ISO19115-3:2018 standard SUCCESS [ 33.035 s]
[INFO] GeoNetwork CSW server .............................. SUCCESS [ 6.025 s]
[INFO] GeoNetwork harvesters .............................. SUCCESS [ 6.789 s]
[INFO] GeoNetwork health monitor .......................... SUCCESS [ 0.983 s]
[INFO] GeoNetwork Digital Object Identifier (DOI) client .. SUCCESS [ 0.703 s]
[INFO] GeoNetwork services ................................ SUCCESS [ 52.606 s]
[INFO] Geonetwork Web Resources 4 Java .................... SUCCESS [01:03 min]
[INFO] GeoNetwork INSPIRE Atom ............................ SUCCESS [ 3.533 s]
[INFO] GeoNetwork index using Elasticsearch ............... SUCCESS [ 0.004 s]
[INFO] GeoNetwork dashboard app based on Kibana ........... SUCCESS [ 0.028 s]
[INFO] Release module ..................................... SUCCESS [ 0.019 s]
[INFO] gn-messaging ....................................... SUCCESS [ 29.861 s]
[INFO] gn-workers ......................................... SUCCESS [ 0.009 s]
[INFO] WFS features harvester ............................. SUCCESS [ 43.886 s]
[INFO] gn-camelPeriodicProducer ........................... SUCCESS [ 6.141 s]
[INFO] gn-es-test ......................................... SUCCESS [ 1.350 s]
[INFO] GeoNetwork Slave ................................... SUCCESS [ 0.558 s]
[INFO] Tests for schema plugins ........................... SUCCESS [ 0.808 s]
[INFO] GeoNetwork user interface module ................... SUCCESS [ 7.122 s]
[INFO] GeoNetwork Web module .............................. SUCCESS [01:59 min]
Do you have any mirror set in .m2/settings.xml? Can you rename your .m2 folder and try again?
On Fri, Oct 1, 2021 at 8:03 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
Hi Juan,
From: Juan Luis Rodríguez Ponce <juanluisrp@...444...<mailto:juanluisrp@…444…>>
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>>
Cc: Geonetwork-Users@...638...<mailto:Geonetwork-Users@…638…> <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>
[INFO]
cd core-geonetwork
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…><mailto:bartolomeo.ventura@…1518…>
Viale Druso 1
I-39100 Bolzano
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
[Image removed by sender.]<http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
Veenderweg 13
6721 WD Bennekom
The Netherlands
(attachments)
I've tried with maven 3.2.8 and I got the same error as you about the
certificate. Using Apache Maven 3.8.2 fixed the problem.
On Fri, Oct 1, 2021 at 12:27 PM Ventura Bartolomeo <
Hi Juan,
mvn -version
Thanks
Bartolomeo
*Sent:* Friday, October 1, 2021 10:31
min]
min]
0.193 s]
0.182 s]
min]
0.308 s]
0.234 s]
0.011 s]
3.568 s]
11.246 s]
27.643 s]
min]
0.753 s]
SUCCESS [ 0.135 s]
0.249 s]
0.217 s]
33.035 s]
6.025 s]
6.789 s]
0.983 s]
0.703 s]
52.606 s]
min]
3.533 s]
0.004 s]
0.028 s]
0.019 s]
29.861 s]
0.009 s]
43.886 s]
6.141 s]
1.350 s]
0.558 s]
0.808 s]
7.122 s]
min]
[INFO]
[INFO]
[INFO]
Hi Juan,
to try again.
this error:
[INFO]
[3:36.289s]
[2:03.848s]
SKIPPED
[INFO]
[INFO]
[INFO]
cd core-geonetwork
3.11 version.
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
!image001.jpg|95x20 <http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
[image: Image removed by sender.] <http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
this email.*
Sorry, with Maven 3.0.5 I got the same error as you. With maven 3.2.5 or
3.8.2 (the other two versions I've tried) it works.
On Fri, Oct 1, 2021 at 4:14 PM Juan Luis Rodríguez Ponce <
Hi Juan,
mvn -version
Thanks
Bartolomeo
min]
[02:08 min]
0.193 s]
0.182 s]
[01:08 min]
0.308 s]
0.234 s]
0.011 s]
3.568 s]
11.246 s]
27.643 s]
[03:40 min]
0.753 s]
SUCCESS [ 0.135 s]
0.249 s]
0.217 s]
33.035 s]
6.025 s]
6.789 s]
0.983 s]
0.703 s]
52.606 s]
[01:03 min]
3.533 s]
0.004 s]
0.028 s]
0.019 s]
29.861 s]
0.009 s]
43.886 s]
6.141 s]
1.350 s]
0.558 s]
0.808 s]
7.122 s]
[01:59 min]
[INFO]
[INFO]
[INFO]
Hi Juan,
you to try again.
getting this error:
[INFO]
[3:36.289s]
[2:03.848s]
SKIPPED
[INFO]
[INFO]
[INFO]
cd core-geonetwork
the 3.11 version.
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
Veenderweg 13
6721 WD Bennekom
The Netherlands
Veenderweg 13
6721 WD Bennekom
The Netherlands
this email.*
this email.*
Hi Juan,
I have updated my maven version to 3.8.2
Apache Maven 3.8.2 (ea98e05a04480131370aa0c110b8c54cf726c06f)
Maven home: /opt/maven
Java version: 1.8.0_302, vendor: Red Hat, Inc., runtime: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.302.b08-0.el7_9.x86_64/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "4.17.0-1.el7.elrepo.x86_64", arch: "amd64", family: "unix"
But it is still not working:
[INFO] GeoNetwork common utils ........................... FAILURE [6.718s]
[INFO] Total time: 8.952s
[INFO] Finished at: Mon Oct 04 06:18:11 UTC 2021
[INFO] Final Memory: 21M/220M
Sent: Friday, October 1, 2021 16:18
Sorry, with Maven 3.0.5 I got the same error as you. With maven 3.2.5 or 3.8.2 (the other two versions I've tried) it works.
On Fri, Oct 1, 2021 at 4:14 PM Juan Luis Rodríguez Ponce <juanluisrp@...444...<mailto:juanluisrp@…444…>> wrote:
I've tried with maven 3.2.8 and I got the same error as you about the certificate. Using Apache Maven 3.8.2 fixed the problem.
On Fri, Oct 1, 2021 at 12:27 PM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
Hi Juan,
mvn -version
Thanks
Bartolomeo
Hi Juan,
[INFO]
cd core-geonetwork
Thanks.
Bartolomeo
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
Veenderweg 13
6721 WD Bennekom
The Netherlands
Veenderweg 13
6721 WD Bennekom
The Netherlands
Veenderweg 13
6721 WD Bennekom
The Netherlands
Veenderweg 13
6721 WD Bennekom
The Netherlands
(attachments)
On Mon, Oct 4, 2021 at 8:21 AM Ventura Bartolomeo <
Hi Juan,
*Apache Maven 3.8.2 (ea98e05a04480131370aa0c110b8c54cf726c06f)*
*Maven home: /opt/maven*
*Java version: 1.8.0_302, vendor: Red Hat, Inc., runtime:
/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.302.b08-0.el7_9.x86_64/jre*
*Default locale: en_US, platform encoding: UTF-8*
*OS name: "linux", version: "4.17.0-1.el7.elrepo.x86_64", arch: "amd64",
family: "unix"*
I don't know what else I can suggest to you. For me version 3.0.5 doesn't
work and 3.8.2 does.
this email.*
Hi there!
It's my first time here, forgive me if I'm taking a wrong way.
I have update 3.12.1 but the Thumbnail Generator from a WMS service isn't work.
The thumbnail genereted is empty as shwon in the following images.
JEANE Patricio Rodrigues
Primeiro-Tenente (RM2-T)
Encarregada da Seção de Controle de Dados (CHM-22)
Centro de Hidrografia da Marinha (CHM)
Tel.: 21 2189-3110 Retelma: 8112-3110
E-mail: jeane@anonymised.com
Banco Nacional de Dados Oceanográficos (BNDO)
E-mail:chm.bndo @marinha.mil.br
Site: [ https://www.marinha.mil.br/chm/dados-do-bndo/acesso-dados-e-produtos | https://www.marinha.mil.br/chm/dados-do-bndo/acesso-dados-e-produtos ]
(attachments)
