[GeoNetwork-users] Can harvest some thredds but not others.
I'm trying to harvest the main catalog [see 1 below] from our thredds server which has datasets primarily on our server but also points to 3 other thredds servers.
It will harvest the top collection datasets from our thredds server but won't get any collection or atomic datasets within these, but can pull the collection and atomic datasets from the external thredds servers. Note that our thredds server has more levels than the external servers.
I can harvest a dataset directly [see 2 below], but there are 73 datasets of interest so I don't want to set up 73 different harvest routines in GeoNetwork.
I can set up a separate thredds server and access most of the datasets this way (some fail - I don't know why). If I leave this failing datasets out of this newly created thredds catalog and then try to harvest it I get the same result as harvesting the source catalog, ie the top collection datasets and the external collection and atomic datasets.
I have the person responsible for our main thredds server looking at proxy issues on the source server, but can anyone suggest any other potential issues?
[1] http://oos.soest.hawaii.edu/thredds/catalog.xml
[2] http://oos.soest.hawaii.edu/thredds/catalog/hioos/model/atm/ncep_global/catalog.xml?dataset=ncep_global/NCEP_Global_Atmospheric_Model_best.ncd
Thanks.
Abe.
  Richard "Abe" Coughlin
SPATIAL DATA & APPLICATIONS SPECIALIST
*Pacific Islands Ocean Observing System*
*University of Hawaii 1-808-956-0822 *
www.pacioos.org <http://www.pacioos.org>
