[GeoNetwork-users] can´t add new wms layer with intermap
Hello,
I wanted to add a wms layer (one of the map list) to intermap through the
map viewer but I get 'the requestest respond can not be performed'. Even if
I try to set up trough harvest managment I can´t do it working.
my stack trace:
java.net.UnknownHostException: aes.gsfc.gov
  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
  at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
  at java.net.Socket.connect(Socket.java:525)
  at java.net.Socket.connect(Socket.java:475)
  at sun.net.NetworkClient.doConnect(NetworkClient.java:163)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:394)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:529)
  at sun.net.www.http.HttpClient.<init>(HttpClient.java:233)
  at sun.net.www.http.HttpClient.New(HttpClient.java:306)
  at sun.net.www.http.HttpClient.New(HttpClient.java:323)
  at
sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:860)
  at
sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:801)
  at
sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:726)
  at
sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1049)
  at org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown
Source)
  at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown
Source)
  at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
  at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
  at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
  at org.jdom.input.SAXBuilder.build(SAXBuilder.java:453)
  at org.jdom.input.SAXBuilder.build(SAXBuilder.java:810)
  at jeeves.utils.Xml.loadFile(Xml.java:103)
  at
org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester.harvest(Harvester.java:199)
  at
org.fao.geonet.kernel.harvest.harvester.ogcwxs.OgcWxSHarvester.doHarvest(OgcWxSHarvester.java:212)
  at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(AbstractHarvester.java:379)
  at org.fao.geonet.kernel.harvest.harvester.Executor.run(Executor.java:87)
I use tomcat 6, geonetwork 2.4.1. Via web browser I can get a respond from
that url.
I have used a few settings:
name: wms , NASA SVS Image Server (read here:
http://n2.nabble.com/Problem-with-map-td2013134.html#a2013135 and
http://n2.nabble.com/Problems-with-interactive-map-td3516222.html#a3516222
that 'name' should be the name of the layer)
url: http://aes.gsfc.nasa.gov/cgi-bin/wms
Furthermore my csw harvest don´t work too (Unknownhostexception). stacktrace
says something about PlainsocketImpl and so on. Don´t use a proxy with gn.
Any suggestions on that? Any help will be appreciated.
Thanks.
best regards
Sarah
View this message in context: http://n2.nabble.com/can-t-add-new-wms-layer-with-intermap-tp3866396p3866396.html
Hi Sarah,
-----Original Message-----
Sent: Thursday, 22 October 2009 12:20 AM
Subject: [GeoNetwork-users] can´t add new wms layer with intermap
Looks like you forgot the "nasa." part in the domain name (see below). Could that be the problem?
HTH,
    Michael
Hi Michael,
yes I forgot that, but it didn´t solve the problem.
I think that it has to do with tomcat or something like that because csw
harvest didn´t work either (UnknownHostException too).
Perhaps a silly question but: I have installed stand alone geoserver at
tomcat again (deployed war-file) after another problem (without
geowebcache-folder). Is this the answer of my problem?
Thanks for any help!
best regards
Sarah
Michael.Stegherr wrote:
Hi Sarah,
HTH,
    Michael
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/can-t-add-new-wms-layer-with-intermap-tp3866396p3870900.html
I have found out that my company is using proxy (using a file/script to
manage this). So I tried to set up proxy settings with system configuration
, but it didn´t work.
Do I even have to change another file? Miss I something?
best regards
Sarah
Sarah_S wrote:
Hi Michael,
best regards
Sarah
Hi Sarah,
HTH,
    Michael
View this message in context: http://n2.nabble.com/can-t-add-new-wms-layer-with-intermap-tp3866396p3873230.html
