[GeoNetwork-users] Cannot Edit metadata in GN??
Hi
I'm having trouble editing the metadata. Data are according GeoNetwork
alright.
Metadata Validation
  Validation against schema definitions succeeded
  Validation against schematron rules succeeded
But as soon as I try to edit and save the corrections I get the following
error.
The requested operation could not be performed.
IllegalStateException : Element not found at ref =
I have also tried to validate data against Inspire Validator - and it goes
well.
Data attached to this tread.
Does anyone know what I can do about the problem?
Regards
Jesper
http://osgeo-org.1803224.n2.nabble.com/file/n5176815/Example.xml Example.xml
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Cannot-Edit-metadata-in-GN-tp5176815p5176815.html
Hi
I solved the problem.
The problem was releated to the <gmd:dateOfNextUpdate> tag.. and now i am
able to save and edit again..
But iam still surprised that all validations where ok - before....
Regards
Jesper
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Cannot-Edit-metadata-in-GN-tp5176815p5181705.html
