When creating a new metadata record using a ISO19139 template, the dates can
only be entered using the date widget. In some cases we only want to enter
the year but we cannot.
Also, if we enter a valid xml document into the system and then use the
editor to make small changed, the date widget changes all the dates - most
of the time it is changing the date to an invalid date. - ie. 2005 changes
to "2013-08-05"
Is there a setting to change this behavior? Or is this a bug?
Using 2.8 nightly build (2012-06-11)
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Cannot-enter-year-as-a-date-using-web-interface-tp4980864.html
According to ISO 8601 a century is a valid date. However one can't enter
a century. eg. '19' for last century, '20' for this century. Can we
change the interface to allow a century to be added?
Thanks.
John
to "2013-08-05"
Thank you.
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
This seems to be related to http://trac.osgeo.org/geonetwork/ticket/661
Ticket #661 . not 100% sure.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Cannot-enter-year-as-a-date-using-web-interface-tp4980864p4981748.html
Hi Ian,
I have been testing GN trunk 2.8+ANZMEST and I get a related issue
i.e date like 2011-12-05T02:12:00Z is altered in XML to 1970-01-01T00:00:00,
date is start of the UNIX epoch I think.
I reported in ticket http://trac.osgeo.org/geonetwork/ticket/960
Andrew
----- Original Message ----- From: "ianwallen" <ianwallen@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Saturday, June 16, 2012 1:22 AM
Subject: Re: [GeoNetwork-users] Cannot enter year as a date using webinterface
The issue seems to be related to the "Ext.form.field.Date". Is there a
setting in the widget to only allow it to select a date but not modify the
existing data. Or maybe there is an option/setting to turn this widget off?
It seems to be causing more issues than it is worth!
View this message in context: http://osgeo-org.1560.n6.nabble.com/Cannot-enter-year-as-a-date-using-web-interface-tp4980864p4982208.html
