[GeoNetwork-users] cannot find java 1.6.0
hi Kristjan,
first of all, your post was not sent to the mailing list; I guess you are
not a member of the mailing list but posted directly to Nabble ? In that
case, fewer people will see it. Please subscribe to the GeoNetwork users
mailing list -- then you can either mail directly to the list, or if you
post to Nabble, the emails should get through.
About your question, it looks strange to me. Could it be that your JAVA_HOME
environment variable was not set correctly before ?
Kind regards
Heikki Doeleman
View this message in context: http://osgeo-org.1560.x6.nabble.com/cannot-find-java-1-6-0-tp5057576p5058583.html
Hi Heikki!
Thank you for answering!
I think I am subscribed now, but I guess for post to be visible, I have to
be subscribed before posting.
It is interesting that just before starting the GN installer, I ran java
-version on my command line, which could not have run without
%JAVA_HOME%\bin being set in Path. JAVA_HOME was set as a system variable
and %JAVA_HOME%\bin was set in Path.
Still, the GN installation started working only after installing JRE on
Google Chrome and it does not seem that it changed or added any environment
variables.
I found this: " Apparently, Chrome addresses a key in Windows registry when
it looks for a Java Environment.
<http://stackoverflow.com/questions/5962048/how-to-configure-chromes-java-plugin-so-it-uses-an-existing-jdk-in-the-machine&gt;
Maybe during the JRE installation to chrome, some registry keys were added
that GN installation needs? If yes, it would be good to write this info to
the GN installation manual!
Best regards,
Kristjan Roosild
View this message in context: http://osgeo-org.1560.x6.nabble.com/cannot-find-java-1-6-0-tp5057576p5058674.html
hi Kristjan,
it still sounds very strange to me. The way you describe it, makes it seem
that installing GeoNetwork depends on the presence of Chrome and a Java
plugin being installed to Chrome.. now that would be a bit unfortunate.
Let's see if anyone else had a similar problem to yours, and how they fixed
it ?
Kind regards
Heikki Doeleman
On Fri, Jun 7, 2013 at 1:11 PM, kristjan <kristjan@anonymised.com> wrote:
Hi Heikki!
variables.
Best regards,
Kristjan Roosild
How ServiceNow helps IT people transform IT departments:
1. A cloud service to automate IT design, transition and operations
2. Dashboards that offer high-level views of enterprise services
3. A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
GeoNetwork-users mailing list
Better description : 1m 46s screencapture video
<https://docs.google.com/file/d/0Bz_zbnQDow6zRE13LUJHSWdwVHc/edit?usp=sharing&gt;
Download (Ctrl+S) for better quality.
View this message in context: http://osgeo-org.1560.x6.nabble.com/cannot-find-java-1-6-0-tp5057576p5058710.html
Try removing the 64 bit installation of java as well, reinstall the correct
jre required, them reinstall software. This worked for me with another
piece of software which received the same error, do not reinstall 64 bit
java files. Hope this works for you.
Sent from my iPad
Toby Te Rupe | 63913275 | 0424890761
toby.terupe@anonymised.com
This message is intended for the addressee named and may contain confidential information.
If you are not the intended recipient, please delete it and notify the sender.
Views expressed in this message are those of the individual sender, and are not necessarily the views of their organisation.
