[GeoNetwork-users] Cannot find the declaration of the element OAI-PMH
Hello,
I just downloaded the new GN2.6 and I wanted to harvest an existing OAI
provider. Unfortunately I receive an error like
    <error id="operation-aborted">
      <message>Raised exception when searching</message>
      <class>OperationAbortedEx</class>
      <stack>
        <at
class="org.fao.geonet.kernel.harvest.harvester.oaipmh.Harvester"
file="Harvester.java" line="171" method="search" />
        <at
file="Harvester.java" line="107" method="harvest" />
        <at
class="org.fao.geonet.kernel.harvest.harvester.oaipmh.OaiPmhHarvester"
file="OaiPmhHarvester.java" line="218" method="doHarvest" />
        <at
class="org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$Harvest
WithIndexProcessor" file="AbstractHarvester.java" line="379"
method="process" />
        <at class="org.fao.geonet.kernel.MetadataIndexerProcessor"
file="MetadataIndexerProcessor.java" line="39"
method="processWithFastIndexing" />
        <at
class="org.fao.geonet.kernel.harvest.harvester.AbstractHarvester"
file="AbstractHarvester.java" line="406" method="harvest" />
        <at class="org.fao.geonet.kernel.harvest.harvester.Executor"
file="Executor.java" line="87" method="run" />
      </stack>
      <object>org.jdom.JDOMException: Exception in startElement:
cvc-elt.1: Cannot find the declaration of element 'OAI-PMH'.</object>
    </error>
I checked the OAI xml format and it seems ok. Do you have any suggestion
for this error?
Maurizio Nagni
Software Developer
British Atmospheric Data Centre
Rutherford Appleton Laboratory
Chilton, Didcot, OX11 0QX
United Kingdom
Phone: +44 (0)1235 567196
E-mail: maurizio.nagni@anonymised.com
Scanned by iCritical.
(attachments)
Hi Maurizio,
I would suggest you to check your OAI harvester is accessing the Internet
because I remember I got an issue with OAI validation against XSD reference
on the Web...
HTH,
Mathieu
On Wed, Nov 17, 2010 at 1:47 PM, <maurizio.nagni@anonymised.com> wrote:
Hello,
     <stack>
       <at
       <at
       <at
       <at
method="process" />
       <at
     </stack>
   </error>
for this error?
Maurizio Nagni
Software Developer
United Kingdom
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
Hello Mathieu,
If you are referring to the proxy configuration in the "System
Configuration" it is already setup.
As far regards the specific OAI configuration the "Validate" check is
not selected.
Also now it fails.
If have time you try to harvest it by yourself at
http://badc.nerc.ac.uk/badc_oai/provider
Maurizio Nagni
Software Developer
United Kingdom
From: Mathieu Coudert [mailto:mathieu.coudert@anonymised.com]
Sent: 17 November 2010 13:28
To: Nagni, Maurizio (STFC,RAL,SSTD)
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Cannot find the declaration of the
element OAI-PMH
Hi Maurizio,
Internet because I remember I got an issue with OAI validation against
XSD reference on the Web...
HTH,
Mathieu
Hello,
     <stack>
       <at
       <at
       <at
       <at
method="process" />
       <at
     </stack>
   </error>
for this error?
Maurizio Nagni
Software Developer
United Kingdom
(attachments)
Maurizio,
On Wed, Nov 17, 2010 at 5:15 PM, <maurizio.nagni@anonymised.com> wrote:
Hello Mathieu,
If you are referring to the proxy configuration in the “System
Configuration” it is already setup.
As far regards the specific OAI configuration the “Validate” check is not
selected.
Also now it fails.
I did not refer to the validate option which refers to the metadata
validation but more to the OAI-PMH response which seems to be validated
with the following specified schema location :
<OAI-PMH xsi:schemaLocation="http://www.openarchives.org/OAI/2.0/
http://www.openarchives.org/OAI/2.0/OAI-PMH.xsd&quot;&gt;
Moreover, it seems that this validation does not take care of the proxy
configuration in Settings, unfortunately.
FYI, I managed to query this data provider using the geonetwork harvester
without any exception but I retrieve no results for the set 'SOLAS' and for
both metadata prefix 'dif' or 'oai_dc'.
At least I did not catch any exception.. So far I suspect an xsd validation
against the remote schemaLocation URL but maybe I'm totally wrong!
Mathieu
Maurizio Nagni
Software Developer
United Kingdom
*From:* Mathieu Coudert [mailto:mathieu.coudert@anonymised.com]
*Sent:* 17 November 2010 13:28
*To:* Nagni, Maurizio (STFC,RAL,SSTD)
*Cc:* geonetwork-users@lists.sourceforge.net
*Subject:* Re: [GeoNetwork-users] Cannot find the declaration of the
element OAI-PMH
Hi Maurizio,
on the Web...
HTH,
Mathieu
Hello,
     <stack>
       <at
       <at
       <at
       <at
method="process" />
       <at
     </stack>
   </error>
for this error?
Maurizio Nagni
Software Developer
United Kingdom
(attachments)
