[GeoNetwork-users] Cannot open GeoNetwork Opensource
I installed the software and follow the quick start guide to get started. I clicked on Start Server and there was a DOS-like window runs for a while. The window never closed itself after started and the last line of word showing in the window was INFO: Started SelectChannelConnector@anonymised.com:8080. Next I clicked on "Open GeoNetwork Opensource". Web browser was opened up at http://localhost:8080/geonetwork/srv/en/main.home. But it said "HTTP ERROR: 404 NOT_FOUND RequestURI=/geonetwork/srv/en/main.home Powered by jetty://". I tried it on IE8, Google Chrome, and Firefox but all of them showed the same error message.
How I can start the program?
Thank you,
Chenglin Gan
hi,
it sounds like you did everything correct, and the message "Started
SelectChannelConnector@anonymised.com:8080" indicates your servlet container
(Jetty) has finished starting correctly. Apparently the GeoNetwork
application did not.
Could you look in the log file ? It's in <installation-dir>/jetty/logs. Try
to find any error message and post it back here ?
Kind regards
Heikki Doeleman
On Thu, Oct 1, 2009 at 5:01 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com> wrote:
Thank you,
Chenglin Gan
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
Here is the log I can find in jetty/logs.
Thanks!!
Chenglin
heikki wrote:
hi,
it sounds like you did everything correct, and the message "Started SelectChannelConnector@anonymised.com:8080" indicates your servlet container (Jetty) has finished starting correctly. Apparently the GeoNetwork application did not.
Could you look in the log file ? It's in <installation-dir>/jetty/logs. Try to find any error message and post it back here ?
Kind regards
Heikki Doeleman
On Thu, Oct 1, 2009 at 5:01 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com <mailto:Chenglin.Gan@anonymised.com>> wrote:
    runs
    of them
    Thank you,
    Chenglin Gan
    Jumpstart your
    and stay
    now&#33;
    <mailto:GeoNetwork-users@lists.sourceforge.net>
Chenglin Gan
GIS Analyst
Office of Coast Survey
National Ocean Service
301-713-2780 x 209
(attachments)
archive.zip (2.46 KB)
hi,
in your log file there is nothing that signals any error. I do see at the
very end that the application is stopping, I suppose that was you stopping
it after you had tried to open GeoNetwork ?
So the next thing to try, I'd say, is to set logging level to DEBUG, which
will give you more information in the log file. You do so by editing
<install-dir>/web/geonetwork/WEB-INF/log4.cfg
and change any INFO, WARN and ERROR levels to DEBUG. Then (re-)start
GeoNetwork. When it's started (and that message "Started
SelectChannelConnector@anonymised.com:8080" has come again), please try again to
open http://localhost:8080/geonetwork, and if it again doesn't work let's
look at your new log file again.
Kind regards
Heikki Doeleman
On Fri, Oct 2, 2009 at 3:36 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com> wrote:
Thanks!!
Chenglin
heikki wrote:
hi,
Kind regards
Heikki Doeleman
On Thu, Oct 1, 2009 at 5:01 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com<mailto:
   runs
   of them
   Thank you,
   Chenglin Gan
   Jumpstart your
   and stay
   now&#33;
Chenglin Gan
GIS Analyst
301-713-2780 x 209
hi,
it's bizarre, according to the logs everything should be dandy. It shows
that your database connection is working fine, and all.
You get the same error ? That indicates that also Jetty is just fine, just
that somehow GeoNetwork seems to be unavailable. But there's nothing in your
log that justifies that.
So now I have no more clue what could be happening there..
This of course is not very satisfactory for you. Hello lists, does anyone
else have an idea now ?
Kind regards
Heikki Doeleman
On Fri, Oct 2, 2009 at 4:53 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com> wrote:
Yeah, I stopped the server after trying to open the geonetwork.
It still doesn't work. Attached is new log file.
Thank you,
Chenglin
heikki wrote:
hi,
to open http://localhost:8080/geonetwork, and if it again doesn't work
let's look at your new log file again.
Kind regards
Heikki Doeleman
On Fri, Oct 2, 2009 at 3:36 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com<mailto:
   Thanks!!
   Chenglin
   heikki wrote:
       hi,
       Kind regards
       Heikki Doeleman
       wrote:
       to get
       window
          runs
       and the last
       said "HTTP
       but all
          of them
          Thank you,
          Chenglin Gan
          Jumpstart your
       market
          and stay
       Register
          now&#33;
       <mailto:GeoNetwork-users@lists.sourceforge.net>>
   -- Chenglin Gan
   GIS Analyst
   301-713-2780 x 209
Chenglin Gan
GIS Analyst
301-713-2780 x 209
2009-10-02 10:48:09,232 INFO [jeeves.engine] - === Starting system
2009-10-02 10:48:09,232 INFO [jeeves.engine] - Java version : 14.2-b01
2009-10-02 10:48:09,232 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2009-10-02 10:48:10,669 INFO [jeeves.engine] - XSLT factory :
net.sf.saxon.IdentityTransformer
2009-10-02 10:48:10,669 INFO [jeeves.engine] - Path : C:\Program
Files\geonetwork\web\geonetwork/
2009-10-02 10:48:10,669 INFO [jeeves.engine] - BaseURL : geonetwork
2009-10-02 10:48:10,669 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config.xml
2009-10-02 10:48:11,169 INFO [jeeves.engine] - Initializing general
configuration...
2009-10-02 10:48:11,169 INFO [jeeves.engine] - Initializing defaults...
2009-10-02 10:48:11,169 INFO [jeeves.engine] - Default local is :true
2009-10-02 10:48:11,216 INFO [jeeves.engine] - Initializing resources...
2009-10-02 10:48:11,216 INFO [jeeves.engine] - Adding resource :
main-db
2009-10-02 10:48:11,216 INFO [jeeves.engine] - Loading activator :
org.fao.geonet.activators.McKoiActivator
2009-10-02 10:48:11,247 INFO [jeeves.engine] - Starting activator :
2009-10-02 10:48:15,263 INFO [jeeves.engine] - Initializing services...
2009-10-02 10:48:15,263 INFO [jeeves.engine] - Adding service :
main.home
2009-10-02 10:48:15,294 INFO [jeeves.engine] - Adding service :
main.search
2009-10-02 10:48:15,309 INFO [jeeves.engine] - Adding service :
main.search.embedded
main.present.embedded
main.searchform.advanced.embedded
main.searchform.simple.embedded
rating.popup
main.present
remote.show
feedback
2009-10-02 10:48:15,309 INFO [jeeves.engine] - Adding service : links
2009-10-02 10:48:15,309 INFO [jeeves.engine] - Adding service : about
xml.region.get
2009-10-02 10:48:15,325 INFO [jeeves.engine] - Adding service :
selection.search
feedback.insert
util.ping
util.import
2009-10-02 10:48:15,341 INFO [jeeves.engine] - Adding service :
user.list
user.get
user.edit
user.resetpw
user.update
2009-10-02 10:48:15,356 INFO [jeeves.engine] - Adding service :
user.remove
user.pwedit
user.pwupdate
user.infoedit
user.infoupdate
user.register.get
user.register.submit
2009-10-02 10:48:15,434 INFO [jeeves.engine] - Adding service :
group.list
group.get
group.update
2009-10-02 10:48:15,450 INFO [jeeves.engine] - Adding service :
group.remove
xml.group.update
2009-10-02 10:48:15,466 INFO [jeeves.engine] - Adding service :
category.list
category.get
category.update
category.remove
xml.category.update
user.login
shib.user.login
user.logout
2009-10-02 10:48:15,466 INFO [jeeves.engine] - Adding service : admin
2009-10-02 10:48:15,466 INFO [jeeves.engine] - Adding service : config
2009-10-02 10:48:15,497 INFO [jeeves.engine] - Adding service :
xml.config.get
xml.config.set
localization
xml.operation.update
2009-10-02 10:48:15,513 INFO [jeeves.engine] - Adding service :
xml.region.update
2009-10-02 10:48:15,513 INFO [jeeves.engine] - Adding service : help
xml.schema.info
file.disclaimer
file.download
prepare.file.download
graphover.show
resources.get.archive
2009-10-02 10:48:15,528 INFO [jeeves.engine] - Adding service :
resources.get
resources.upload
resources.prepare.upload
resources.del
2009-10-02 10:48:15,544 INFO [jeeves.engine] - Adding service :
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
xml.info
xml.forward
xml.user.list
xml.usergroups.list
xml.group.list
xml.metadata.insert
2009-10-02 10:48:15,559 INFO [jeeves.engine] - Adding service :
xml.metadata.delete
2009-10-02 10:48:15,559 INFO [jeeves.engine] - Adding service : csw
2009-10-02 10:48:15,559 INFO [jeeves.engine] - Adding service : oaipmh
rss.latest
rss.search
rss.present
google.kml
mef.import
mef.export
2009-10-02 10:48:15,575 INFO [jeeves.engine] - Adding service :
xml.relation.get
xml.relation.insert
xml.relation.delete
keywords.getselected
keywords.sort
keywords.select
keywords.search
xml.search.keywords
xml.search.keywordlink
keywords.editsearch
2009-10-02 10:48:15,591 INFO [jeeves.engine] - Adding service :
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
thesaurus.editelement
2009-10-02 10:48:15,638 INFO [jeeves.engine] - Adding service :
thesaurus.addelement
thesaurus.updateelement
thesaurus.deleteelement
2009-10-02 10:48:15,638 INFO [jeeves.engine] - Initializing schedules...
2009-10-02 10:48:15,638 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config-metadata.xml
2009-10-02 10:48:15,653 INFO [jeeves.engine] - Initializing services...
2009-10-02 10:48:15,653 INFO [jeeves.engine] - Adding service :
metadata.insert.paste
metadata.insert
metadata.show
metadata.show.embedded
metadata.edit
2009-10-02 10:48:15,669 INFO [jeeves.engine] - Adding service :
metadata.elem.add
metadata.elem.delete
metadata.update
metadata.update.finish
metadata.update.forget
metadata.update.forgetandfinish
metadata.validate
metadata.elem.down
metadata.elem.up
metadata.attr.add
metadata.attr.delete
metadata.delete
2009-10-02 10:48:15,684 INFO [jeeves.engine] - Adding service :
metadata.recent.additions.embedded
metadata.massive.delete
metadata.massive.newowner
metadata.massive.newowner.form
metadata.massive.category.form
metadata.massive.update.categories
metadata.massive.admin.form
metadata.massive.update.privileges
metadata.massive.processing
metadata.select
2009-10-02 10:48:15,700 INFO [jeeves.engine] - Adding service :
metadata.create.form
metadata.duplicate.form
metadata.create
metadata.admin.index.rebuild
metadata.admin.form
metadata.admin
metadata.category.form
metadata.category
metadata.xmlinsert.form
metadata.batchimport.form
2009-10-02 10:48:15,716 INFO [jeeves.engine] - Adding service :
metadata.searchunused.form
metadata.thumbnail.form
metadata.thumbnail.set
metadata.thumbnail.unset
2009-10-02 10:48:15,731 INFO [jeeves.engine] - Adding service :
transfer.ownership
xml.ownership.editors
xml.ownership.groups
xml.ownership.transfer
xml.metadata.rate
2009-10-02 10:48:15,731 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config-harvesting.xml
2009-10-02 10:48:15,747 INFO [jeeves.engine] - Initializing services...
2009-10-02 10:48:15,747 INFO [jeeves.engine] - Adding service :
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.update
2009-10-02 10:48:15,763 INFO [jeeves.engine] - Adding service :
xml.harvesting.remove
xml.harvesting.start
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
2009-10-02 10:48:15,778 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config-portal.xml
2009-10-02 10:48:15,794 INFO [jeeves.engine] - Initializing services...
2009-10-02 10:48:15,794 INFO [jeeves.engine] - Adding service :
portal.search
portal.opensearch
portal.search.keywords
portal.present
portal.search.present
portal.get
portal.full
portal.latest.updated
portal.featured
portal.categories
portal.sources
pdf.search
2009-10-02 10:48:15,794 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config-export.xml
2009-10-02 10:48:15,794 INFO [jeeves.engine] - Adding service : dc.xml
fgdc.xml
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
Files\geonetwork\web\geonetwork/WEB-INF/config-test.xml
2009-10-02 10:48:15,809 INFO [jeeves.engine] - Initializing services...
2009-10-02 10:48:15,809 INFO [jeeves.engine] - Adding service :
test.i18n
test.i18n.xml
test.csw
2009-10-02 10:48:15,809 INFO [jeeves.engine] - Loading : C:\Program
Files\geonetwork\web\geonetwork/WEB-INF/config-csw.xml
2009-10-02 10:48:15,809 INFO [jeeves.engine] - Initializing profiles...
2009-10-02 10:48:15,825 INFO [jeeves.engine] - Found handler :
org.fao.geonet.Geonetwork
2009-10-02 10:48:15,825 INFO [jeeves.engine] - --- Starting handler
2009-10-02 10:48:15,825 INFO [jeeves.apphand] - Initializing geonetwork...
2009-10-02 10:48:15,825 INFO [jeeves.apphand] - - Setting manager...
2009-10-02 10:48:15,872 DEBUG [jeeves.dbms.select] - Query : SELECT * FROM
Settings
2009-10-02 10:48:15,903 DEBUG [jeeves.dbms.select] - Found 76 records in
0.031 secs
2009-10-02 10:48:15,934 INFO [jeeves.apphand] - - Thesaurus...
2009-10-02 10:48:16,106 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus
: external.place.regions
2009-10-02 10:48:16,731 INFO [jeeves.apphand] - - Z39.50...
2009-10-02 10:48:16,731 INFO [jeeves.apphand] - Enabled. Schema
mappings is : schema-mappings.xml
2009-10-02 10:48:16,919 INFO [jeeves.apphand] - - Search...
2009-10-02 10:48:21,856 INFO [jeeves.apphand] - - Access manager...
2009-10-02 10:48:21,887 DEBUG [jeeves.dbms.select] - Query : SELECT * FROM
Operations
2009-10-02 10:48:21,919 DEBUG [jeeves.dbms.select] - Found 6 records in
0.032 secs
2009-10-02 10:48:21,919 INFO [jeeves.apphand] - - Data manager...
2009-10-02 10:48:21,950 DEBUG [jeeves.dbms.select] - Query : SELECT id,
changeDate FROM Metadata ORDER BY id ASC
2009-10-02 10:48:21,965 DEBUG [jeeves.dbms.select] - Found 7 records in
0.015 secs
2009-10-02 10:48:21,981 DEBUG [geonetwork.datamanager] - DB CONTENT:
'<response>
<record>
   <id>1</id>
   <changedate>2009-10-01T10:15:59</changedate>
</record>
<record>
   <id>2</id>
</record>
<record>
   <id>3</id>
</record>
<record>
   <id>4</id>
</record>
<record>
   <id>5</id>
</record>
<record>
   <id>6</id>
</record>
<record>
   <id>7</id>
</record>
</response>'
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - INDEX CONTENT:
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (1)
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - lastChange:
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - idxLastChange:
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (2)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (3)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (4)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (5)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (6)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - - record (7)
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-02 10:48:22,028 DEBUG [geonetwork.datamanager] - INDEX SURPLUS:
2009-10-02 10:48:22,028 INFO [jeeves.apphand] - Adding xml schema :
csw-record
2009-10-02 10:48:22,559 INFO [jeeves.apphand] - Adding xml schema :
dublin-core
2009-10-02 10:48:22,669 INFO [jeeves.apphand] - Adding xml schema :
fgdc-std
2009-10-02 10:48:23,028 INFO [jeeves.apphand] - Adding xml schema :
iso19115
2009-10-02 10:48:23,168 INFO [jeeves.apphand] - Adding xml schema :
iso19139
2009-10-02 10:48:25,059 INFO [jeeves.apphand] - - Harvest manager...
2009-10-02 10:48:25,122 INFO [jeeves.apphand] - - Catalogue services for
the web...
2009-10-02 10:48:25,122 INFO [geonetwork.csw] - Loading : C:\Program
Files\geonetwork\web\geonetwork//WEB-INF/config-csw.xml
2009-10-02 10:48:25,215 INFO [jeeves.apphand] - - Open Archive
Initiative (OAI-PMH) server...
2009-10-02 10:48:25,262 INFO [jeeves.apphand] - Site ID is :
072837fa-3ebd-4003-81c6-afd8b49fd21b
2009-10-02 10:48:25,278 INFO [jeeves.engine] - --- Handler started
2009-10-02 10:48:25,278 INFO [jeeves.engine] - Starting schedule
manager...
2009-10-02 10:48:25,278 INFO [jeeves.engine] - Memory used is : 11731 Kb
2009-10-02 10:48:25,278 INFO [jeeves.engine] - Total memory is : 520256 Kb
2009-10-02 10:48:25,278 INFO [jeeves.engine] - Startup time is : 16 (secs)
2009-10-02 10:48:25,278 INFO [jeeves.engine] - === System working
could it be that this is a description of the same symptom ?
http://n2.nabble.com/IE8-error-message-Env-is-undefined-td3716612.html
On Fri, Oct 2, 2009 at 5:02 PM, heikki <tropicano@anonymised.com> wrote:
hi,
Kind regards
Heikki Doeleman
On Fri, Oct 2, 2009 at 4:53 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com>wrote:
Thank you,
Chenglin
heikki wrote:
hi,
which will give you more information in the log file. You do so by editing
Kind regards
Heikki Doeleman
   Thanks!!
   Chenglin
   heikki wrote:
       hi,
       Kind regards
       Heikki Doeleman
       wrote:
       to get
       window
          runs
       and the last
       said "HTTP
       but all
          of them
          Thank you,
          Chenglin Gan
          Jumpstart your
       market
          and stay
       Register
          now&#33;
   -- Chenglin Gan
   GIS Analyst
   301-713-2780 x 209
Chenglin Gan
GIS Analyst
301-713-2780 x 209
Microsystems Inc.
configuration...
main-db
main.home
main.search
rating.popup
main.present
remote.show
feedback
xml.region.get
selection.search
feedback.insert
util.ping
util.import
user.list
user.get
user.edit
user.resetpw
user.update
user.remove
user.pwedit
user.pwupdate
user.infoedit
user.infoupdate
user.register.get
group.list
group.get
group.update
group.remove
xml.group.update
category.list
category.get
category.update
category.remove
xml.category.update
user.login
shib.user.login
user.logout
xml.config.get
xml.config.set
localization
xml.region.update
xml.schema.info
file.disclaimer
file.download
graphover.show
resources.get
resources.upload
resources.del
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
xml.info
xml.forward
xml.user.list
xml.usergroups.list
xml.group.list
xml.metadata.insert
xml.metadata.delete
rss.latest
rss.search
rss.present
google.kml
mef.import
mef.export
xml.relation.get
xml.relation.insert
xml.relation.delete
keywords.sort
keywords.select
keywords.search
xml.search.keywords
keywords.editsearch
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
metadata.insert
metadata.show
metadata.edit
metadata.elem.add
metadata.update
metadata.validate
metadata.elem.down
metadata.elem.up
metadata.attr.add
metadata.delete
metadata.select
metadata.create
metadata.admin.form
metadata.admin
metadata.category
transfer.ownership
xml.metadata.rate
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
portal.search
portal.opensearch
portal.present
portal.get
portal.full
portal.featured
portal.categories
portal.sources
pdf.search
fgdc.xml
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
test.i18n
test.i18n.xml
test.csw
geonetwork...
Settings
0.031 secs
thesaurus : external.place.regions
Operations
0.032 secs
0.015 secs
'<response>
<record>
   <id>1</id>
</record>
<record>
   <id>2</id>
</record>
<record>
   <id>3</id>
</record>
<record>
   <id>4</id>
</record>
<record>
   <id>5</id>
</record>
<record>
   <id>6</id>
</record>
<record>
   <id>7</id>
</record>
</response>'
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
2009-10-01T10:15:59
csw-record
dublin-core
fgdc-std
iso19115
iso19139
for the web...
manager...
Kb
(secs)
Thanks for your help Heikki! Could this problem caused by firewall setting or some kind of IT security enforced on my desktop?
Chenglin
heikki wrote:
hi,
it's bizarre, according to the logs everything should be dandy. It shows that your database connection is working fine, and all.
You get the same error ? That indicates that also Jetty is just fine, just that somehow GeoNetwork seems to be unavailable. But there's nothing in your log that justifies that.
This of course is not very satisfactory for you. Hello lists, does anyone else have an idea now ?
Kind regards
Heikki Doeleman
On Fri, Oct 2, 2009 at 4:53 PM, Chenglin.Gan <Chenglin.Gan@anonymised.com <mailto:Chenglin.Gan@anonymised.com>> wrote:
    Thank you,
    Chenglin
    heikki wrote:
        hi,
        see at the very end that the application is stopping, I
        suppose that was you stopping it after you had tried to open
        GeoNetwork ?
        DEBUG, which will give you more information in the log file.
        (re-)start GeoNetwork. When it's started (and that message
        "Started SelectChannelConnector@anonymised.com:8080" has come
        again), please try again to open
        Kind regards
        Heikki Doeleman
        wrote:
           Thanks!!
           Chenglin
           heikki wrote:
               hi,
        indicates your
        message
               Kind regards
               Heikki Doeleman
        <mailto:Chenglin.Gan@anonymised.com> <mailto:Chenglin.Gan@anonymised.com
        <mailto:Chenglin.Gan@anonymised.com>>>>
               wrote:
        guide
               to get
        DOS-like
               window
                  runs
        started
               and the last
        clicked on "Open
        But it
               said "HTTP
               but all
                  of them
                  Thank you,
                  Chenglin Gan
        year.
                  Jumpstart your
        applications to
               market
                  and stay
        2009.
               Register
                  now&#33;
        <mailto:GeoNetwork-users@lists.sourceforge.net>>>
           -- Chenglin Gan
           GIS Analyst
           301-713-2780 x 209
    -- Chenglin Gan
    GIS Analyst
    301-713-2780 x 209
    system ========================================
    14.2-b01
    Microsystems Inc.
    C:\Program Files\geonetwork\web\geonetwork/
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config.xml
    general configuration...
    defaults...
    is :true
    resources...
    : main-db
    activator : org.fao.geonet.activators.McKoiActivator
    services...
    : main.home
    : main.search
    : main.search.embedded
    : main.present.embedded
    : main.searchform.advanced.embedded
    : main.searchform.simple.embedded
    : rating.popup
    : main.present
    : remote.show
    : feedback
    : links
    : about
    : xml.region.get
    : selection.search
    : feedback.insert
    : util.ping
    : util.import
    : user.list
    : user.get
    : user.edit
    : user.resetpw
    : user.update
    : user.remove
    : user.pwedit
    : user.pwupdate
    : user.infoedit
    : user.infoupdate
    : user.register.get
    : user.register.submit
    : group.list
    : group.get
    : group.update
    : group.remove
    : xml.group.update
    : category.list
    : category.get
    : category.update
    : category.remove
    : xml.category.update
    : user.login
    : shib.user.login
    : user.logout
    : admin
    : config
    : xml.config.get
    : xml.config.set
    : localization
    : xml.operation.update
    : xml.region.update
    : help
    : xml.schema.info <http://xml.schema.info>
    : file.disclaimer
    : file.download
    : prepare.file.download
    : graphover.show
    : resources.get.archive
    : resources.get
    : resources.upload
    : resources.prepare.upload
    : resources.del
    : xml.user.login
    : xml.user.logout
    : xml.search
    : xml.metadata.get
    : xml.info <http://xml.info>
    : xml.forward
    : xml.user.list
    : xml.usergroups.list
    : xml.group.list
    : xml.metadata.insert
    : xml.metadata.delete
    : csw
    : oaipmh
    : rss.latest
    : rss.search
    : rss.present
    : google.kml
    : mef.import
    : mef.export
    : xml.relation.get
    : xml.relation.insert
    : xml.relation.delete
    : keywords.getselected
    : keywords.sort
    : keywords.select
    : keywords.search
    : xml.search.keywords
    : xml.search.keywordlink
    : keywords.editsearch
    : thesaurus.admin
    : thesaurus.upload
    : thesaurus.download
    : thesaurus.delete
    : thesaurus.view
    : thesaurus.add
    : thesaurus.edit
    : thesaurus.update
    : thesaurus.editelement
    : thesaurus.addelement
    : thesaurus.updateelement
    : thesaurus.deleteelement
    schedules...
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config-metadata.xml
    services...
    : metadata.insert.paste
    : metadata.insert
    : metadata.show
    : metadata.show.embedded
    : metadata.edit
    : metadata.elem.add
    : metadata.elem.delete
    : metadata.update
    : metadata.update.finish
    : metadata.update.forget
    : metadata.update.forgetandfinish
    : metadata.validate
    : metadata.elem.down
    : metadata.elem.up
    : metadata.attr.add
    : metadata.attr.delete
    : metadata.delete
    : metadata.recent.additions.embedded
    : metadata.massive.delete
    : metadata.massive.newowner
    : metadata.massive.newowner.form
    : metadata.massive.category.form
    : metadata.massive.update.categories
    : metadata.massive.admin.form
    : metadata.massive.update.privileges
    : metadata.massive.processing
    : metadata.select
    : metadata.create.form
    : metadata.duplicate.form
    : metadata.create
    : metadata.admin.index.rebuild
    : metadata.admin.form
    : metadata.admin
    : metadata.category.form
    : metadata.category
    : metadata.xmlinsert.form
    : metadata.batchimport.form
    : metadata.searchunused.form
    : metadata.thumbnail.form
    : metadata.thumbnail.set
    : metadata.thumbnail.unset
    : transfer.ownership
    : xml.ownership.editors
    : xml.ownership.groups
    : xml.ownership.transfer
    : xml.metadata.rate
    C:\Program
    services...
    : harvesting
    : xml.harvesting.get
    : xml.harvesting.add
    : xml.harvesting.update
    : xml.harvesting.remove
    : xml.harvesting.start
    : xml.harvesting.stop
    : xml.harvesting.run
    : xml.harvesting.info <http://xml.harvesting.info>
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config-portal.xml
    services...
    : portal.search
    : portal.opensearch
    : portal.search.keywords
    : portal.present
    : portal.search.present
    : portal.get
    : portal.full
    : portal.latest.updated
    : portal.featured
    : portal.categories
    : portal.sources
    : pdf.search
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config-export.xml
    services...
    : dc.xml
    : fgdc.xml
    : iso19115to19139.xml
    : iso19139.xml
    : iso_arccatalog8.xml
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config-test.xml
    services...
    : test.i18n
    : test.i18n.xml
    : test.csw
    C:\Program Files\geonetwork\web\geonetwork/WEB-INF/config-csw.xml
    profiles...
    handler --------------------------------------
    geonetwork...
    manager...
    SELECT * FROM Settings
    records in 0.031 secs
    Schema mappings is : schema-mappings.xml
    SELECT * FROM Operations
    records in 0.032 secs
    SELECT id, changeDate FROM Metadata ORDER BY id ASC
    records in 0.015 secs
    '<response>
     <record>
       <id>1</id>
     </record>
     <record>
       <id>2</id>
     </record>
     <record>
       <id>3</id>
     </record>
     <record>
       <id>4</id>
     </record>
     <record>
       <id>5</id>
     </record>
     <record>
       <id>6</id>
     </record>
     <record>
       <id>7</id>
     </record>
    </response>'
    CONTENT:
    lastChange: 2009-10-01T10:15:59
    idxLastChange: 2009-10-01T10:15:59
    SURPLUS:
    schema : csw-record
    schema : dublin-core
    schema : fgdc-std
    schema : iso19115
    schema : iso19139
    manager...
    services for the web...
    C:\Program Files\geonetwork\web\geonetwork//WEB-INF/config-csw.xml
    started ---------------------------------------
    manager...
    11731 Kb
    520256 Kb
    16 (secs)
Chenglin Gan
GIS Analyst
301-713-2780 x 209
Oct 02, 2009; 05:15pm Thanks for your help Heikki! Could this problem caused
Chenglin
Hello Chenglin, Heikki, Jason and Jeroen.
Three of us (Chenglin, Prestige Jul 24 and me) have this Error 404 problem.
:jumping: Thanks to Jeroen
(http://n2.nabble.com/Still-after-trying-for-weeks-HTTP-ERROR-404-Here-is-the-loggfile-td3693953.html#a3693953)
I tried to remove the GeoServer folder the way Jeroen said in the link
above.
Now I get GeoNetwork up and running in Firefox without the mapwindow as
expected.
This means I can "talk" to my local host, so I stop worring about internal
settings and "Intranet firewalls" or whatever - right?
I post this now, if you, Chenglin, are working Saturdays, so you can try
removing GeoServer to.
I will look into the logg and also the Forum because of Jason remark on Sep
22:
"This seems to be an issue with Geoserver, not Geonetwork, and I think it
has been discussed on the list over the past few weeks. Is geonetwork
running or it is just an intermap issue? Best regards, jason"
I really would like to get GeoNetwork up and running on my new Dell
Precision T7400 and not the old Dell Dimension 8200!
Regards Anders Söderman Sweden
View this message in context: http://n2.nabble.com/Cannot-open-GeoNetwork-Opensource-tp3749662p3759167.html
Thanks, this solution worked fine to me, regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-open-GeoNetwork-Opensource-tp3862635p5071105.html
