I have found mention of the "Timer already cancelled" error at URL:
http://osdir.com/ml/users/2010-07/msg01393.html
which says to
'Remove "timeBetweenEvictionRunsMillis" attribute, or set it to "-1".'
which I have done in
the /geonetwork/webapps/geonetwork/WEB-INF/config.xml file. This didn't
fix the problem but I have noticed the following errors in the
catalina.out file:
2012-05-31 17:18:01,736 INFO [jeeves.engine] - Adding resource :
main-db
2012-05-31 17:18:01,740 WARN [jeeves.dbmspool] - Using transaction
isolation setting SERIALIZABLE
31/05/2012 5:18:01 PM org.geotools.data.postgis.PostgisDBInfo <init>
SEVERE: ERROR: function postgis_version() does not exist
Hint: No function matches the given name and argument types. You might
need to add explicit type casts.
Position: 8
2012-05-31 17:18:02,114 INFO [jeeves.engine] - Initializing
services...
2012-05-31 17:18:02,582 INFO [jeeves.engine] - Adding service : csw
2012-05-31 17:18:02,583 WARN [jeeves.engine] - Raised exception while
registering service. Skipped.
2012-05-31 17:18:02,583 WARN [jeeves.engine] - Service : csw
2012-05-31 17:18:02,583 WARN [jeeves.engine] - Package :
org.fao.geonet
2012-05-31 17:18:02,583 WARN [jeeves.engine] - Exception :
java.lang.ClassNotFoundException:
org.fao.geonet.services.main.CswDispatcher
2012-05-31 17:18:02,583 WARN [jeeves.engine] - Message :
2012-05-31 17:18:02,584 WARN [jeeves.engine] - Stack :
at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at
jeeves.server.dispatchers.ServiceManager.buildService(ServiceManager.java:210)
at
jeeves.server.dispatchers.ServiceManager.addService(ServiceManager.java:173)
at
jeeves.server.JeevesEngine.initServices(JeevesEngine.java:582)
at
jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:300)
at
jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:317)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:152)
at
jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:76)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1206)
at
org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1026)
at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4421)
2012-05-31 17:18:06,667 DEBUG [jeeves] - Adding xml to /summary/def
2012-05-31 17:18:08,321 WARN [geonetwork.spatial] - Failure to make
_writer, maybe a problem but might also not be an issue:<error
id="error">
<message />
<class>NullPointerException</class>
<stack>
<at class="org.fao.geonet.kernel.search.spatial.SpatialIndexWriter"
file="SpatialIndexWriter.java" line="129" method="<init>" />
<at class="org.fao.geonet.kernel.search.SearchManager$Spatial"
file="SearchManager.java" line="1412" method="createWriter" />
file="SearchManager.java" line="1390" method="<init>" />
<at class="org.fao.geonet.kernel.search.SearchManager"
file="SearchManager.java" line="373" method="<init>" />
<at class="org.fao.geonet.Geonetwork" file="Geonetwork.java"
line="339" method="start" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="525" method="initAppHandler" />
line="161" method="init" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="76" method="init" />
<at class="javax.servlet.GenericServlet" file="GenericServlet.java"
line="212" method="init" />
<at class="org.apache.catalina.core.StandardWrapper"
file="StandardWrapper.java" line="1206" method="loadServlet" />
<skip>...</skip>
</stack>
</error>
2012-05-31 17:18:08,321 ERROR [geonetwork.spatial] - Unable to call
reset on Spatial writer: null
java.lang.NullPointerException
at org.fao.geonet.kernel.search.SearchManager
$Spatial.createWriter(SearchManager.java:1419)
$Spatial.<init>(SearchManager.java:1390)
at
org.fao.geonet.kernel.search.SearchManager.<init>(SearchManager.java:373)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:339)
at
jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:525)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:161)
at
at
at
at
at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4734)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
at
org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1079)
at
org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1002)
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:506)
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at
org.apache.catalina.core.StandardService.start(StandardService.java:525)
2012-05-31 17:18:08,324 ERROR [geonetwork.index] - Rebuilding lucene
index
2012-05-31 17:18:08,612 INFO [jeeves.apphand] - - Access manager...
2012-05-31 17:18:08,620 INFO [jeeves.apphand] - - Xml serializer and
Data manager...
2012-05-31 17:18:08,646 WARN [geonetwork.settings] - Unable to find
Settings row for: system/site/svnUuid. Check settings table.
2012-05-31 17:18:09,308 WARN [geonetwork.svnmanager] - Recreating
subversion repository
at /data/jakarta/geonetwork-asdd/webapps/geonetwork/WEB-INF/data/metadata_subversion as previous repository was empty
2012-05-31 17:18:09,505 INFO [jeeves.apphand] - - Harvest manager...
2012-05-31 17:18:10,217 INFO [jeeves.apphand] - - Catalogue services
for the web...
2012-05-31 17:18:10,250 INFO [jeeves.apphand] - - Open Archive
Initiative (OAI-PMH) server...
2012-05-31 17:18:10,273 INFO [jeeves.apphand] - - Metadata
notifier ...
2012-05-31 17:18:10,273 INFO [jeeves.apphand] - Site ID is :
dd714eee-01f6-4d00-a84c-16a03a50a3f4
2012-05-31 17:18:10,277 INFO [jeeves.engine] - --- Handler started
2012-05-31 17:18:10,277 INFO [jeeves.engine] - Starting schedule
manager...
2012-05-31 17:18:10,278 INFO [jeeves.engine] - Memory used is :
-113902 Kb
2012-05-31 17:18:10,278 INFO [jeeves.engine] - Total memory is :
3728320 Kb
2012-05-31 17:18:10,278 INFO [jeeves.engine] - Startup time is : 8
(secs)
2012-05-31 17:18:10,278 INFO [jeeves.engine] - === System working
31/05/2012 5:18:10 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
INFO: Server startup in 19261 ms
2012-05-31 17:18:19,551 ERROR [geonetwork.datamanager] - The metadata
document index with id=1 is corrupt/invalid - ignoring it. Error: null
at
org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.<init>(SpatialIndexWriter.java:129)
$Spatial.writerNoLocking(SearchManager.java:1529)
$Spatial.writer(SearchManager.java:1515)
at
org.fao.geonet.kernel.search.SearchManager.delete(SearchManager.java:835)
at
org.fao.geonet.kernel.search.SearchManager.buildIndexDocument(SearchManager.java:721)
at
org.fao.geonet.kernel.search.SearchManager.index(SearchManager.java:639)
at
org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:524)
at org.fao.geonet.kernel.DataManager
$IndexMetadataTask.run(DataManager.java:340)
at java.util.concurrent.ThreadPoolExecutor
$Worker.runTask(ThreadPoolExecutor.java:886)
$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Exception in thread "Timer-1" java.lang.NullPointerException
at org.fao.geonet.kernel.search.SearchManager$Spatial
$Committer.run(SearchManager.java:1560)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
Any hints on what to do to fix this would be greatly appreciated.
I'm running:
psql (PostgreSQL) 8.4.11
contains support for command-line editing
and it appears to have the 270 dagaa bs upgrades.
Thanks.
John H.
On Thu, 2012-05-31 at 14:30 +1000, john.hockaday wrote:
Hi All,
Sorry for cross posting.
I have tried to fix the "corrupt/invalid ignoring it. Error: Timer
already cancelled." error by doing the following:
sudo su - postgres
psql -d gndb
delete from metadatarating;
delete from validation;
delete from metadatacateg;
delete from operationallowed;
delete from metadata;
reindex database gndb force;
\q
I had to delete from the metadarating, validation, metadatacateg and
operationallowed because of links to the metadata table or each other.
I then start GN and tried to load just one services metadata record. The
catalina.out file showed this:
</gmd:function>
</gmd:CI_OnlineResource>
</srv:connectPoint>
</srv:SV_OperationMetadata>
</srv:containsOperations>
</srv:SV_ServiceIdentification>
</gmd:identificationInfo>
</gmd:MD_Metadata></data>
<group>11</group>
<uuidAction>overwrite</uuidAction>
<validate>on</validate>
<file_type>single</file_type>
</request>
2012-05-31 14:13:41,911 ERROR [geonetwork.datamanager] - The metadata
at
at
at
at
at
2012-05-31 14:13:41,913 INFO [jeeves.service] - -> dispatching to
output for : metadata.insert.paste
2012-05-31 14:13:41,929 INFO [jeeves.service] - -> transforming
with
stylesheet : /data/jakarta/geonetwork-asdd/webapps/geonetwork/xsl/metadata-insert-results.xsl
2012-05-31 14:13:41,957 ERROR [geonetwork.datamanager] - The metadata
at
at
at
at
at
2012-05-31 14:13:42,854 INFO [jeeves.service] - -> end
transformation for : metadata.insert.paste
2012-05-31 14:13:42,854 INFO [jeeves.service] - -> output ended
2012-05-31 14:13:42,855 INFO [jeeves.service] - -> dispatch ended
2012-05-31 14:14:03,028 INFO [jeeves.request] -
2012-05-31 14:14:03,028 INFO [jeeves.request] - HTML Request (from
175.107.172.1) : /geonetwork/srv/en/metadata.show
2012-05-31 14:14:03,028 DEBUG [jeeves.request] - Method : GET
2012-05-31 14:14:03,028 DEBUG [jeeves.request] - Content type : null
2012-05-31 14:14:03,029 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2012-05-31 14:14:03,029 DEBUG [jeeves.request] - Session id is
C8678D2BE6E8F6FA3D2238FB96A32FAB
2012-05-31 14:14:03,029 INFO [jeeves.service] - Dispatching :
metadata.show
2012-05-31 14:14:03,029 DEBUG [jeeves.service] - -> parameters are :
<request>
<id>1</id>
</request>
2012-05-31 14:14:03,118 INFO [jeeves.service] - -> dispatching to
output for : metadata.show
2012-05-31 14:14:03,129 ERROR [geonetwork.datamanager] - The metadata
document index with id=1 is corrupt/invalid - ignoring it. Error: Timer
already cancelled.
java.lang.IllegalStateException: Timer already cancelled.
at java.util.Timer.sched(Timer.java:354)
at java.util.Timer.schedule(Timer.java:170)
$Spatial.writer(SearchManager.java:1514)
at
2012-05-31 14:14:03,129 INFO [jeeves.webapp.metadata.show] - Creating
default metadata tab
at
at
at
2012-05-31 14:14:03,130 INFO [jeeves.webapp.metadata.show] - Creating
default metadata position
$IncreasePopularityTask.run(DataManager.java:3168)
2012-05-31 14:14:03,137 DEBUG [jeeves.service] - Log search in asynch
mode - start.
2012-05-31 14:14:03,141 DEBUG [jeeves.service] - Log search in asynch
mode - end.
2012-05-31 14:14:03,162 DEBUG [jeeves.service] - Log search in asynch
mode - start.
mode - end.
2012-05-31 14:14:03,169 DEBUG [jeeves.service] - Log search in asynch
mode - start.
2012-05-31 14:14:03,171 DEBUG [jeeves.service] - Log search in asynch
mode - end.
2012-05-31 14:14:03,259 INFO [jeeves.service] - -> transforming
with
stylesheet : /data/jakarta/geonetwork-asdd/webapps/geonetwork/xsl/metadata-show.xsl
2012-05-31 14:14:06,893 INFO [jeeves.service] - -> end
transformation for : metadata.show
2012-05-31 14:14:06,893 INFO [jeeves.service] - -> output ended
for : metadata.show
2012-05-31 14:14:06,893 INFO [jeeves.service] - -> dispatch ended
for : metadata.show
Where should I look next to fix this problem? Why does the "Timer
already cancelled" error keep on coming up when I have cleared all the
metadata and relations from the postgis database?
Any help would be much appreciated.
Thanks.
John H.
On Wed, 2012-05-30 at 17:19 +1000, john.hockaday wrote:
> Hi All,
> I have GN 2.7 snapshot. I have managed to get the system setup but when
> I do a search for metadata I get zero results. This also applies when I
> am logged in as 'admin'.
> I tried to create "New metadata" but I am told "No templates available,
> import templates first". If I then go back and select a template in the
> pick list eg. 'anzmeta' then select "Add templates"
> I saw Andrea Peri's post in the archives about copying
> WEB-INF/data/config
> into the
> DATA_DIRECTORY/config
> but I don't have those directories.
> I get the following in the catalina.out file when I try to load the
> anzmeta template:
> (See attached addAnzmetaTemplate.txt for output)
> I still get the same error when I select "New metadata"
> If I select 19139 metadata schema and then select "Add template" I get
> the follow errors in the catalina.out file:
> (See attached add19139Template.txt for output)
> If I try to "Add sample metadata" for the 19139 schema I get the
> following in the catalina.out file:
> (See attached add19139SampleMetadata.txt for output)
> and the message:
> (See attached Screenshot.png for Error Message Box)
> Have I broken my Postgis database? Can I fix it somehow? I don't want to
> lose all the services metadata and harvesting configuration that I have
> in the database.
> Thanks.
> John Hockaday
> Live Security Virtual Conference
> Exclusive live event will cover all the ways today's security and
> threat landscape has changed and how IT managers can respond. Discussions
> will include endpoint security, mobile security and the latest in malware
> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> _______________________________________________ GeoNetwork-users mailing list GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
