This is a problem that in former posts by other users had no solution (please
see:
http://osgeo-org.1803224.n2.nabble.com/Re-Issues-with-geonetwork-under-tomcat-tp3307894p3307894.html)
I'm trying to install GN on Debian 5.0.4 with Tomcat 5.5 and PostgreSQL 8.3.
I set up the db using Gast with no problem. But when I run geonetwork I
can't login as admin/admin and make a search. Same problem: THE REQUESTED
OPERATION COULD NOT BE PERFORMED. NullPointerException :
The list of categories are correctly displayed and the folders privileges
seem ok.
Thank you for your help.
Bye
Paolo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-login-or-make-a-search-tp5064285p5064285.html
hello,
please go back to java 1.5 - i've got some strange errors with 2.4.3 and java
1.6 under lenny!
regards
armin
Am Montag 17 Mai 2010 11:28:05 schrieb Paolo Pasquali:
(please see:
8.3. I set up the db using Gast with no problem. But when I run geonetwork
I can't login as admin/admin and make a search. Same problem: THE REQUESTED
seem ok.
Bye
Paolo
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
The problem was solved changing the geonetwork owner to tomcat55.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-login-or-make-a-search-tp5064285p5064378.html
