[GeoNetwork-users] Can't make Tomcat 5.5 and GeoNetwork 2.2.0 work together
Hello.
I'm trying to configure GeoNetwork 2.2.0 for working with Tomcat 5.5 on Windows. Sorry, this is the configuration of our hosting site...
When I test the site with the embedd Jetty J2EE server, it works fine. Even when I use a MySQL 5 database.
But it always crashed when trying to use Tomcat.
I was curious and I test the same configuration on my mac (PowerPC G4) and the result is the same : work with Jetty but "nada" with Tomcat.
What is the trick ?
Thank you for your precious help.
The configuration :
Apache Tomcat/5.5.23
JVM 1.5.0_12-b04
Windows XP (5.1 x86) (have no choice, sorry)
Tomcat server.xml
    <Context
     path="/geonetwork"
     docBase="D:/Tomcat/5.5.23/webapps/catalogue/geonetwork220/web/geonetwork"
     crossContext="false"
     debug="1"
     reloadable="false" />
Tomcat localhost.log
28 oct. 2008 09:43:27 org.apache.catalina.core.ApplicationContext log
GRAVE: StandardWrapper.Throwable
java.lang.ExceptionInInitializerError
at jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:183)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:132)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:65)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1139)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:966)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3956)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4230)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
Caused by: java.lang.IllegalArgumentException: http://www.w3.org/2001/XMLSchema
at javax.xml.validation.SchemaFactory.newInstance(Unknown Source)
at jeeves.utils.Xml.<clinit>(Xml.java:262)
... 21 more
28 oct. 2008 09:43:27 org.apache.catalina.core.StandardContext loadOnStartup
GRAVE: La servlet /geonetwork a généré une exception "load()"
And after trying to acces to http://localhost:8080/geonetwork/
java.lang.NoClassDefFoundError
  at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:791)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:127)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
  at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:834)
  at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:640)
  at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1286)
  at java.lang.Thread.run(Unknown Source)
28 oct. 2008 09:46:23 org.apache.catalina.core.StandardWrapperValve invoke
GRAVE: Exception lors de l'allocation pour la servlet gn-servlet
Geonetwork.log
2008-10-28 09:43:27,095 INFO [jeeves.engine] - === Starting system ========================================
2008-10-28 09:43:27,095 INFO [jeeves.engine] - Java version : 1.5.0_12-b04
2008-10-28 09:43:27,110 INFO [jeeves.engine] - Java vendor : Sun Microsystems Inc.
2008-10-28 09:43:27,126 INFO [jeeves.engine] - XSLT factory : org.apache.xalan.transformer.TransformerIdentityImpl
2008-10-28 09:43:27,126 INFO [jeeves.engine] - Path : D:\Tomcat\5.5.23\webapps\catalogue\geonetwork220\web\geonetwork\/
2008-10-28 09:43:27,126 INFO [jeeves.engine] - BaseURL : geonetwork
2008-10-28 09:43:27,126 INFO [jeeves.engine] - Loading : D:\Tomcat\5.5.23\webapps\catalogue\geonetwork220\web\geonetwork\/WEB-INF/config.xml
Maël REBOUX
Cellule SIG
Rennes Métropole
