I am running GeoNetwork 2.8 RC2 installed from the jar on Windows 7.
I am seeing an issue where after I assign a category to a record that was added to my catalog via harvesting, the category association does not persist if that record is updated the next time the harvest is run.
Example:
Harvest record A
Create Category 'foo'
Assign 'foo' to record A
Click on the 'foo' category on the search page
Record A is found.
Re-harvest Record A
Record A is not found (without searching for other specifics, it still exists)
Is this something others are seeing? Is this knew, or a known issue (I didn't see any mention of it in the last few years worth of posts to the developer or user lists).
Please let me know if there's already a solution, or if I'll have to fix this myself.
Ryan Hodges | Applications Developer | Ecotrust
721 NW 9th Avenue, Suite 200 * Portland, OR 97209
T (503) 467.0800 | F (503) 222.1517 | www.ecotrust.org<http://www.ecotrust.org/>
Hi Ryan,
I think we are facing the same global re-Harvest consistency pb.
http://osgeo-org.1560.n6.nabble.com/Changed-privileges-after-harvest-tc5018787.html
I can also testify that I get the same category pb. that you describe after
re-harvest.
Have you experience the privileges pb. after re-harvet that I describe in my
post ?
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Categories-not-persisting-through-harvest-update-tp5020016p5020049.html
Hi Lionel, Ryan et. al
Sounds like a bug. Best to report this issue on Geonetwork Trac site at
http://trac.osgeo.org/geonetwork/
Read the section titled 'Bug Reporting' on the Trac web page. This shows
how you can get a login so you can create and submit bug tickets.
Andrew
----- Original Message ----- From: "Lionel Menard" <lionel.menard@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Saturday, December 01, 2012 10:25 PM
Subject: Re: [GeoNetwork-users] Categories not persisting through harvestupdate
Hi Ryan,
re-harvest.
post ?
Lionel
Keep yourself connected to Go Parallel:
INSIGHTS What's next for parallel hardware, programming and related areas?
Interviews and blogs by thought leaders keep you ahead of the curve.
http://goparallel.sourceforge.net
GeoNetwork-users mailing list
Hi Andrew and Lionel,
Andrew, at your request I have created a ticket: http://trac.osgeo.org/geonetwork/ticket/1174
Lionel, I agree that these seem to be related and I have replicated your issue. Your concerns are addressed in the above ticket as well.
-----Original Message-----
Sent: Sunday, December 02, 2012 6:12 PM
To: Lionel Menard
Cc: geonetwork-users@lists.sourceforge.net
Sounds like a bug. Best to report this issue on Geonetwork Trac site at http://trac.osgeo.org/geonetwork/
Read the section titled 'Bug Reporting' on the Trac web page. This shows how you can get a login so you can create and submit bug tickets.
Andrew
Hi Ryan,
re-harvest.
post ?
Lionel
BUILD Helping you discover the best ways to construct your parallel projects.
Hi Ryan,
thanks a lot for taking over this action.
Did you check the response of Francois stating that he was not able to
reproduce the error.
I don't know exactly the procedure regarding ticket creation but there seems
to have different point of view ?
Thanks a lot anyway.
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Categories-not-persisting-through-harvest-update-tp5020016p5020525.html
