I have a problem with the category management, when I assign to a metadata
form a category the software doesn’t retain it at the time of the seeking.
On the other hand there is no problem with the pre-existent categories of
the software when I search a metadata form by categories, the software find
the metadate form without problem.
Has anybody already had this problem? Needs it not to reinstall, to delete
this problem or has it a solution easier ?
Thank you for your answer
Did you try to force re-build of the lucene index?
For that just try to restart your geonetwork after deleting the lucene
repository under the WEB-INF repository.
HTH,
Mathieu
On Tue, Apr 1, 2008 at 7:11 PM, INRH <benjamin.robert@anonymised.com> wrote:
form a category the software doesn't retain it at the time of the seeking.
find
delete
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
Does Mathieu's tip solve the problem?
I have tried to delete the lucene repository but it doesn't work better...
Any other idea?
Eliane
Mathieu Coudert-2 wrote:
Hi Benjamin,
HTH,
Mathieu
metadata
seeking.
find
delete
