[GeoNetwork-users] Change default similarity
Hi. I have changed the default similarity on the main-page.xsl (I have set to
0.2) but when I do a simple search I get the same results that with default
similarity is set to 0.8. Can I set default similarity on simple search?
Thank you.
View this message in context: http://www.nabble.com/Change-default-similarity-tp20954824p20954824.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
hi,
no, not just like that, because the parameter is not sent in simple search.
If you modify <installation-dir>/web/geonetwork/scripts/gn_search.js like
this :
in function runSimpleSearch()
add the line
    pars += fetchRadioParam('similarity');
then it should work.
Regards
Heikki Doeleman
to
Thank you.
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
GeoNetwork-users mailing list
I'll try it. Thank you
View this message in context: http://www.nabble.com/Change-default-similarity-tp20954824p20971388.html
