Hello
In version 2.02 I can change the area of the map in the file main-page.xsl (Usually there's a map of the world)
There are few settings like (near line 300)
var myWest = -12;
var myEast = 45;
var mySouth = 25;
var myNorth = 58;
var map = new quickWMS(-12, 25, 45, 58);
where = myWest+","+mySouth+","+myEast +","+myNorth ;
But I can't find them in the version 2.1
How can I change this ?
Thank you for you help
Hervé TRON
Office International de l'Eau
Hello Hervé, you should have a look to the scripts/gn_search.js and
update the resetSimpleSearch, resetAdvancedSearch and doRegionSearch
function to adapt the lat lon boundaries I guess.
Maybe, check the searchform_simple_template.xsl for default value.
HTH. Francois
Hervé TRON wrote:
Hello
var myWest = -12;
var myEast = 45;
var mySouth = 25;
var myNorth = 58;
Hervé TRON
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
francois-xavier.prunayre@anonymised.com
The files are both modified but I didn't notice any change.
Any other suggestion ?
Hervé
----- Message d'origine ----- De : "Francois-Xavier Prunayre" <francois-xavier.prunayre@anonymised.com>
À : "Hervé TRON" <ht@anonymised.com>
Cc : <geonetwork-users@lists.sourceforge.net>
Envoyé : mardi 20 novembre 2007 23:54
Objet : Re: [GeoNetwork-users] Change Map in version 2.1
HTH. Francois
Hervé TRON wrote:
Hello
var myWest = -12;
var myEast = 45;
var mySouth = 25;
var myNorth = 58;
Hervé TRON
If you click on the "reset" link under the map, doest it zoom to the
area you defined ?
if yes, you need to call the function to update the zoom area when page
is loading.
HTH. Francois
Hervé
HTH. Francois
Hervé TRON wrote:
Hello
var myWest = -12;
var myEast = 45;
var mySouth = 25;
var myNorth = 58;
Hervé TRON
