[GeoNetwork-users] Change metadata pdf header
I have changed the PDF template used for the map printing, but I would also
like to change the graphic used for the metadata search results export to
PDF. Where is that graphic located?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Change-metadata-pdf-header-tp6361152p6361152.html
I have determined that the PDF header is comprised of header-left.jpg and
header-right.gif located in the img directory. The pdf header is generated
in metadata-fop.xsl. By adding a new image (header-pdf.jpg) and referencing
that in metadata-fop.xsl I was able to use a custom header graphic.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Change-metadata-pdf-header-tp6361152p6363767.html
