Hi, I want to change the default map to a certain area map, instead of the map of whole world, in the section of search of GN homepage. Does anybody know how to do it?
_________________________________________________________________
Ò»ÕÅÕÕƬµÄ×԰סª¡ªWindows LiveÕÕƬµÄ¿É°®ÊÓƵ½éÉÜ
http://windowslivesky.spaces.live.com/blog/cns!5892B6048E2498BD!889.entry
In this directory: GN_inst_dir/web/intermap/scripts/
File : im_minimap.js
Set : im_mm.setBBox(maxY,maxX,minY,minX)
bye
Marc-Andre
-----Message d'origine-----
De : chenll [mailto:c_lyun@…29…]
Envoyé : 5 avril 2010 09:08
À : geonetwork-user
Objet : [GeoNetwork-users] change the default map of intermap viewer
一张照片的自白——Windows Live照片的可爱视频介绍
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
GeoNetwork-users mailing list
This message has been verified by LastSpam eMail security service
Ce courriel a 閠?v閞ifi?par le service de s閏urit?pour courriels LastSpam
http://www.lastspam.com
Thanks, Marc-Andre, i have doon it according to your suggestion.
To: c_lyun@...29...; geonetwork-users@lists.sourceforge.net
Date: Tue, 6 Apr 2010 09:29:41 -0400
Subject: RE: [GeoNetwork-users] change the default map of intermap viewerIn this directory: GN_inst_dir/web/intermap/scripts/
bye
Marc-Andre
À : geonetwork-user
Objet : [GeoNetwork-users] change the default map of intermap viewerHi, I want to change the default map to a certain area map, instead of the map of whole world, in the section of search of GN homepage. Does anybody know how to do it?
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork--
This message has been verified by LastSpam eMail security serviceCe courriel a 閠?v閞ifi?par le service de s閏urit?pour courriels LastSpam
SkyDrive电子画册,带你领略精彩照片,分享“美”时“美”刻!
http://www.windowslive.cn/campaigns/e-magazine/ngmchina/?a=c
Thanks for this, but how do I change the default map and point to my own map
service?
Regards
Prestige
On Tue, Apr 6, 2010 at 3:39 PM, magoderre [via OSGeo.org] <
ml-node+4859008-637887720-116942@anonymised.com<ml-node%2B4859008-637887720-116942@anonymised.com>
bye
Marc-Andre
De : chenll [mailto:[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4859008&i=0>\]Envoyé : 5 avril 2010 09:08
À : geonetwork-user
know how to do it?_________________________________________________________________
http://windowslivesky.spaces.live.com/blog/cns!5892B6048E2498BD!889.entry<http://windowslivesky.spaces.live.com/blog/cns!5892B6048E2498BD!889.entry>
------------------------------------------------------------------------------Download Intel® Parallel Studio Eval
[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4859008&i=1>
http://www.lastspam.com------------------------------------------------------------------------------
[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4859008&i=2>
http://sourceforge.net/projects/geonetwork------------------------------
View message @
http://n2.nabble.com/change-the-default-map-of-intermap-viewer-tp4853405p4859008.html
To unsubscribe from GeoNetwork opensource, click here< (link removed) =>.
View this message in context: http://n2.nabble.com/change-the-default-map-of-intermap-viewer-tp4853405p4870111.html
You have to edit this file : GN_inst_dir/web/intermap/WEB-INF/mapServers.xml.
Add server and mapcontext corresponding to your own server and comment those already added.
Best regards
Marc-André
De : Prestige [mailto:ptmakanga@…54…]
Envoyé : 8 avril 2010 05:47
À : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] change the default map of intermap viewer
service?
Regards
Prestige
ml-node+4859008-637887720-116942@...456...<ml-node%2B4859008-637887720-116942@...456...>
bye
Marc-Andre
À : geonetwork-user
View message @
Ce courriel a �t� v�rifi� par le service de s�curit� pour courriels LastSpam
I modified it too, but it seems that it works only with non-minified version
of the JS files (with ?debug parameter into the URL). So FYI you will
probably have to go into jsbuild/ directory and rebuild the minified version
of the scripts.
Pierre Mauduit
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)4 79 44 44 92
http://www.camptocamp.com
pierre.mauduit@anonymised.com
version of the JS files (with ?debug parameter into the URL). So FYI you
will probably have to go into jsbuild/ directory and rebuild the minified
version of the scripts.
After having investigated a bit, I found out that the im_class.js was
minified before the im_minimap.js file. With this behaviour, there was some
js code (var im_mm = new Intermap(...)) located in im_minimap.js executed
before the object Intermap was defined. I attached a patch to fix the js
building process of intermap's minified version (at least, I have no more
error with Firebug after rebuilding, and the use of bounding box seems now
functionning).
Hth,
Pierre Mauduit
(attachments)
jsbuild_im.patch (377 Bytes)
I attached a patch to fix the js building process of intermap's minified
version (at least, I have no more error with Firebug after rebuilding, and
the use of bounding box seems now functionning).
Sorry, this patch is better than the previous one attached (since
im_extras.js has to be loaded before the other scripts, or else changing the
opacity on the "big map" will call an alert()).
Pierre Mauduit
(attachments)
jsbuild_im.patch (354 Bytes)
Thanks for the fix Pierre. Committed revision 5946.
Do you know any Java libs which could be used to minify JS instead of jsbuild ?
A java lib could be run by the ant process which could be a better option.
Ciao.
Francois
2010/4/8 Pierre Mauduit <pierre.mauduit@anonymised.com>:
the use of bounding box seems now functionning).Sorry, this patch is better than the previous one attached (since
Pierre MauduitCamptocamp France SAS
pierre.mauduit@anonymised.com------------------------------------------------------------------------------
GeoNetwork-devel mailing list
