[GeoNetwork-users] Changed privileges after harvest
I've schedule a harvest of a GeoServer. I've set the record to be "public"
in the Harvesting Management (privileges for the Group "All" set for: View,
Interactive Map, Featured)
The problem is that once the harvest run again all the privileges are reset
I must manually reconfigure the privileges to make my records publicly
visible.
IS this a bug or do I miss a feature ?
Version:2.9.0-SNAPSHOT
Thanks for your help.
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changed-privileges-after-harvest-tp5018787.html
no one got an idea on this matter. Bug or am I missing something ?
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changed-privileges-after-harvest-tp5018787p5019802.html
Not something I can help with... so you get at least one acknowledgment of the question :slight_smile:
I know that harvested records should NOT be editable... but that doesn't seem to relate to your problem.
Brent
--- On Fri, 11/30/12, Lionel Menard <lionel.menard@anonymised.com> wrote:
Subject: Re: [GeoNetwork-users] Changed privileges after harvest
To: geonetwork-users@lists.sourceforge.net
Date: Friday, November 30, 2012, 9:41 PM
Lionel
Keep yourself connected to Go Parallel:
TUNE You got it built. Now make it sing. Tune shows you how.
http://goparallel.sourceforge.net
GeoNetwork-users mailing list
Thanks Brent for your acknowledgment...It Keeps the forum alive :slight_smile:
I by chance you (or any forumer) could please make a test to see if it also
happen to you ?
1/ Harvest a GeoServer and set a schedule (day, week.. whatever).
2/ Make your harvested data with privileges set to "All" (publicly
available).
3/ When re-harvested with the scheduler the records are not set anymore with
"All" even if you specify this in the harvest option.
4/ You have to manually re-assigned this "All" privileges afterwards which
is time consuming.
Does this happen to some of you ?
I'm sure you harvest with schedule some GeoServer.
Thanks for any report you might provides.
Thanks Brent and all...
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changed-privileges-after-harvest-tp5018787p5020036.html
Hello Lionel,
I can't reproduce the issue on master branch, do you have any errors in the
log ?
Cheers.
Francois
PS : same for category, it works fine for me locally.
2012/12/1 Lionel Menard <lionel.menard@anonymised.com>
happen to you ?
available).
with
is time consuming.
Lionel
INSIGHTS What's next for parallel hardware, programming and related areas?
Interviews and blogs by thought leaders keep you ahead of the curve.
Hi Francois,
I've check in the log of the 24/10/2012 that is the moment where the harvest
has been made and could not find any clues to figure out what went wrong for
the privileges assignment.
Here is a grep of the ERROR for this day. If you could find any hints that
could help to solve this out I could provide more focused log on the
dedicated period.
Thanks a lot.
Lionel
[root@anonymised.com tomcat6]# grep ERROR geonetwork.log.2012-10-24
2012-10-24 09:06:13,935 ERROR [jeeves.service] - Exception when executing
service
2012-10-24 09:06:13,935 ERROR [jeeves.service] - (C) Exc :
java.lang.Exception: Request must contain a UUID (uuid) or an ID (id)
2012-10-24 11:38:42,825 ERROR [jeeves.service] - Exception when executing
service
2012-10-24 11:38:42,825 ERROR [jeeves.service] - (C) Exc :
java.lang.IllegalStateException: Element not found at ref = 235
2012-10-24 11:38:47,468 ERROR [geonetwork.editor] - Version mismatch: had 3
but expected 5
2012-10-24 11:38:47,468 ERROR [jeeves.service] - Exception when executing
service
2012-10-24 11:38:47,468 ERROR [jeeves.service] - (C) Exc :
ConcurrentUpdateEx : Concurrent update
2012-10-24 11:39:04,465 ERROR [geonetwork.editor] - Version mismatch: had 3
but expected 5
2012-10-24 11:39:04,466 ERROR [jeeves.service] - Exception when executing
service
2012-10-24 11:39:04,466 ERROR [jeeves.service] - (C) Exc :
2012-10-24 11:39:24,240 ERROR [geonetwork.editor] - Version mismatch: had 3
but expected 5
2012-10-24 11:39:24,240 ERROR [jeeves.service] - Exception when executing
service
2012-10-24 11:39:24,240 ERROR [jeeves.service] - (C) Exc :
2012-10-24 11:44:34,477 ERROR [geonetwork.editor] - Element not found at ref
= 274Id
= 119Id
2012-10-24 11:44:34,478 ERROR [geonetwork.editor] - Element not found at ref
= 137Id
2012-10-24 11:44:34,479 ERROR [geonetwork.editor] - Element not found at ref
= 61Id
= 55Id
2012-10-24 11:44:34,480 ERROR [geonetwork.editor] - Element not found at ref
= 49Id
2012-10-24 16:31:02,440 ERROR [geonetwork.search] - Errors occurred when
trying to parse a filter:
org.xml.sax.SAXParseException: cvc-complex-type.2.4.b: The content of
element 'ogc:Filter' is not complete. One of
'{"http://www.opengis.net/ogc&quot;:spatialOps,
"http://www.opengis.net/ogc&quot;:comparisonOps,
"http://www.opengis.net/ogc&quot;:logicOps, "http://www.opengis.net/ogc&quot;:\_Id\}' is
expected.
2012-10-24 16:31:03,040 ERROR [geonetwork.search] - Errors occurred when
expected.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changed-privileges-after-harvest-tp5018787p5020426.html
