Hi Shireeb
The permissions are set in Java code, so not easy to change unless rebuild
GeoNetwork (see DataManager.copyDefaultPrivForGroup).
The metadata create services accepts a param fullPrivileges, that is not
used by default. You can change xsl/metadata-create.xsl to add it:
<form id="createform" name="createform" accept-charset="UTF-8"
action="{/root/gui/locService}/metadata.create" method="post">
* <input type="hidden" name="fullPrivileges" value="true" />*
This will make that the metadata gets all the permissions for the group
where is created. No fine grain permission selection (unless Java changes),
but better than the bizarre default permissions assigned for view and
notify. Possibly there's a reason for these default permissions, but I
can't see it.
Jose García
On Thu, Jan 23, 2014 at 11:57 PM, shireeb <s.brockie@anonymised.com> wrote:
Is there a way to change the default privileges that are automatically set
when a metadata record is created using GN's editor?
By default "Publish" and "Notify" are checked for the Group selected when
creating the record. Can the system be configured to instead (for example)
check "Publish" and "Editing" for the Group selected?
We want to avoid a user to having to do this manually.
Any help much appreciated.
Many Thanks
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Changing-configuration-of-default-privileges-set-at-record-creation-GN-v2-10-2-tp5099759.html
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
