Hello list
Still using html5ui with GN 2.10.2
i want to customize metadata presentation (change field order) in the metadata viewer.
Which files (template, css, js ?) should i check for that ?
Thanks
Philippe<http://www.paca.inra.fr/emmah>
Hello list
Thanks
2014-02-06 18:39 GMT+01:00 Philippe Clastre <
Philippe.Clastre@anonymised.com>:
Hello list
metadata viewer.
For the simple view mode for iso19139 records, see
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/present/metadata-view.xsl#L51
Cheers.
Francois
Thanks
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
