[GeoNetwork-users] Changing Geonetwork schema
Hi List,
I'm wondering what method people use to change the schema that
metadata is stored in. The scenario- I want to convert records in
Gemini 2.2 (iso19139.gemini22) format to Gemini 2.3
(iso19139.gemini23). I can change the actual metadata using an xsl
transformation, but as far as Geonetwork's database is concerned, the
records are still stored with a schemaid of iso19139.gemini22. I can
manually update the records in the database to change from one to the
other, but that's not ideal for end-users of the catalog who may want
to use a phased approach for converting and not do them all at once.
What other methods have people used to fully convert records in place?
I really don't want to harvest into a new catalog, or export and
re-import them if at all possible.
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Please note that currently I do not work on Friday afternoons. For
urgent responses at that time, please visit
support.astuntechnology.com or phone our office on 01372 744009
*Sign up to our mailing list
<https://astuntechnology.com/company/#email-updates&gt; for updates on news,
products, conferences, events and training*
Astun Technology Ltd,
Epsom Square Centre, 6-7 The Derby Square, Epsom, Surrey, KT19 8AG, UK
t:+44 1372 744 009 w: astuntechnology.com <http://astuntechnology.com/&gt;
twitter:@astuntech <https://twitter.com/astuntech&gt;
iShare - enterprise
geographic intelligence platform <https://astuntechnology.com/ishare/&gt;
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/training-courses/&gt;
Helpdesk and customer
portal
<https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Hi Jo,
We are facing a similar issue with a small number of metadata records in the database from iso19115-3 going to iso19115-3.2018. We do not have a conclusion yet. Below I describe some of the approaches we are considering. I hope this is helpful, or at least starts discussion, raises other questions, and potentially results in a “best practice” that I will volunteer to write for the documentation.
We considered adding the -3 to -3.2018 xsl transform to the list of transforms on the “Import new records” page. Then we could export the 2014 version files, and then import (and transform) with the overwrite metadata with same uuid option. We have not yet tested that to see if the metadata database record is fully and correctly updated with the schemid. I do not have a deep knowledge of the code and am not sure if this was ever defined as a requirement or test case. I too am hesitant to do things in unanticipated ways and have established a rule that our external programs will access the geonetwork database in read-only mode.
We also considered exporting the metadata records, using GeoNetwork to delete the older schema records, and then import keeping the uuid in the import file. My thought is this would force the deletion of the database metadata record, so when imported, it would have to create an entire new record. BUT this has the side effect of the metadata.id value changing. I am not sure if that is good, neutral, or causes problems.
Regardless of the way to update the records, I would guess that it would be good to force reindexing.
We have the added complexity of using many “directories”/“snippets”/“re-usable element content”/some other name. We also have nested snippets - responsibleParty snippet contains a link to a contact snippet that contains an onlineResource snippet. How to export the metadata.data field without resolving the xlinks to snippets is not entirely clear. We have written some postgres queries to write the content of metadata.data to a file. I noticed that the code for the download file list of formats seems to have parameters that could allow specifying that the xlinks should not be resolved. We have not figured out how to do that.
Bigger Picture
We have several hundred published records at this time all stored as 19139. Many were transformed from legacy metadata formats. Since we expect potentially many thousands of records starting from legacy formats, or perhaps minimal formal metadata, we are thinking about training for 19115-3.2018 instead of the double learning curve for 19139 and then 19115-3.x. If we decide that 19115-3.2018 is our primary internal format, it seems to make sense to convert the snippets to that format instead of on-the-fly transforms of 19139 to 19115-3.2018. In that case, the conversion becomes much more difficult and risky if the snippet uuid has to be changed.
Any comments and questions are welcome. We’re also happy to contribute code, but our customization is minimal, so far.
Jeff
On 3/17/2020 2:05 PM, Jo Cook wrote:
Hi List,
Thanks
Jo
Hi
You can add in the schema that you want to upgrade in the process folder a
file ending with the suffix -schemaupgrade.xsl that makes the upgrade,
changing the elements in the xml to match the new schema and updating the
schemaid in the database, the process can be invoked using
XlsProcessingApi and MetadataProcessApi, but both seem oriented to single
metadata updates.
See
https://github.com/geonetwork/core-geonetwork/commit/7f22142621c834abc431ac859b06de087962d7f7
Jose García
On Tue, Mar 17, 2020 at 9:24 PM Jeff Campbell <
dev@anonymised.com> wrote:
Hi Jo,
questions, and potentially results in a "best practice" that I will
transforms on the "Import new records" page. Then we could export the 2014
"directories"/"snippets"/"re-usable element content"/some other name. We
Bigger Picture
be changed.
Any comments and questions are welcome. We're also happy to contribute
Jeff
Hi List,
Thanks
Jo
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Jose,
That's great news- I will try it out. Is it something that would easily
backport to 3.4? (Happy to give it a go if it's simple enough).
Thanks
Jo
On Wed, Mar 18, 2020 at 9:30 AM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
Please note that currently I do not work on Friday afternoons. For urgent
responses at that time, please visit support.astuntechnology.com or phone
iShare - enterprise
portal
864201149.
Hi Jo
The changed files should be quite similar in 3.4.x. I'll check if can
manage tomorrow to make a PR.
Jose García
On Thu, Mar 19, 2020 at 5:31 PM Jo Cook <jocook@anonymised.com> wrote:
Hi Jose,
Thanks
Jo
wrote:
Hi
a file ending with the suffix -schemaupgrade.xsl that makes the upgrade,
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
Astun Technology Ltd, Epsom Square Centre, 6-7 The Derby Square, Epsom,
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
Helpdesk and customer portal
864201149.
this email.*
Hi Jose (and list)
I can get this process working via the api just fine, but I'm struggling
with getting it working as a suggestion. With the files from
https://github.com/AstunTechnology/iso19139.gemini22_GN3/commit/25417e5be1ddd692cf676ea23c335d106bc9618f
the suggestion appears in the list but when it's run I get the following
error:
(URL:
http://localhost:8080/geonetwork/srv/api/records/918/processes/iso19139.gemini23-schemaupgrade?process=iso19139.gemini23-schemaupgrade&id=918
<apiError>
<code>runtime_exception</code>
<description>
Not found:0, Not owner:0, No process found:1. is not a valid value for:
Processing failed
</description>
<message>BadParameterEx</message>
</apiError>
and I'm really not sure what I am doing wrong. Any ideas?
Thanks
Jo
On Thu, Mar 19, 2020 at 4:33 PM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Jose García
wrote:
Hi Jose,
Thanks
Jo
wrote:
Hi
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
iShare - enterprise
portal
864201149.
Hi Jo
It seems from the error that can't find the xsl in the schema related to
the metadata with id 918
I understand the xslt *iso19139.gemini23-schemaupgrade* is in the GEMINI
2.2 schema and the metadata with the id 918 is a GEMINI 2.2 record correct?
Jose García
On Fri, Mar 20, 2020 at 2:03 PM Jo Cook <jocook@anonymised.com> wrote:
Hi Jose (and list)
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
wrote:
Hi Jo
Jose García
wrote:
Hi Jose,
Thanks
Jo
wrote:
Hi
folder a file ending with the suffix -schemaupgrade.xsl that makes the
upgrade, changing the elements in the xml to match the new schema and
updating the schemaid in the database, the process can be invoked using
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
urgent responses at that time, please visit support.astuntechnology.com or
864201149.
this email.*
*Jo Cook*
864201149.
this email.*
Hi Jo,
I think the url you're using might be wrong, can you try
http://localhost:8080/geonetwork/srv/api/0.1/records/918/processes/iso19139.gemini23-schemaupgrade
<http://geo-dev.nal.usda.gov:8080/geonetwork/srv/api/0.1/records/m_3807708_se_18_1_20170725/processes/iso19115-3.2018-schemaupgrade&gt;
In the swagger api document, it's
/api/0.1/records/{metadataUuid}/processes/{process}
<https://geodata-stage.nal.usda.gov/geonetwork/doc/api/#/operations/records/processRecordPreview&gt;
I tried to upgrade our iso19115-3 to iso19115-3.2018 using that api, it
works. But I'm using version 3.10.1.
Zhuoyue
On Fri, Mar 20, 2020 at 9:03 AM Jo Cook <jocook@anonymised.com> wrote:
Hi Jose (and list)
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
wrote:
> Hi Jo
> Regards,
> Jose García
> wrote:
>> Hi Jose,
>> Thanks
>> Jo
>> wrote:
>>> Hi
folder
upgrade,
the
single
>>> metadata updates.
>>> See
>>> Regards,
>>> Jose García
>>>> Hi Jo,
have a
considering.
2014
metadata
metadata
do not
defined
programs
the
database
new
name. We
to a
export the
content
file
that
that.
>>>> Bigger Picture
expect
format,
of
has to
>>>> be changed.
>>>> Jeff
>>>> Hi List,
>>>> Thanks
>>>> Jo
>>>> _______________________________________________
NetherlandsT: +31
printing
>>> this email.*
>> *Jo Cook*
urgent
news,
>> 864201149.
+31
printing
> this email.*
*Jo Cook*
iShare - enterprise
portal
864201149.
Just to clarify, the URLs that are not localhost are in our development environment with no public access.
Zhuoyue and I are working on the same project.
Jeff
On 3/20/2020 9:57 AM, Xiawucha ZZ wrote:
Hi Jo,
[http://localhost:8080/geonetwork/srv/api/0.1/records/918/processes/iso19139.gemini23-schemaupgrade](http://localhost:8080/geonetwork/srv/api/0.1/records/918/processes/iso19139.gemini23-schemaupgrade)
[<http://geo-dev.nal.usda.gov:8080/geonetwork/srv/api/0.1/records/m_3807708_se_18_1_20170725/processes/iso19115-3.2018-schemaupgrade>](http://geo-dev.nal.usda.gov:8080/geonetwork/srv/api/0.1/records/m_3807708_se_18_1_20170725/processes/iso19115-3.2018-schemaupgrade)
[<https://geodata-stage.nal.usda.gov/geonetwork/doc/api/#/operations/records/processRecordPreview>](https://geodata-stage.nal.usda.gov/geonetwork/doc/api/#/operations/records/processRecordPreview)
Zhuoyue
On Fri, Mar 20, 2020 at 9:03 AM Jo Cook [<jocook@anonymised.com>](mailto:jocook@anonymised.com) wrote:
Hi Jose (and list)
[https://github.com/AstunTechnology/iso19139.gemini22_GN3/commit/25417e5be1ddd692cf676ea23c335d106bc9618f](https://github.com/AstunTechnology/iso19139.gemini22_GN3/commit/25417e5be1ddd692cf676ea23c335d106bc9618f)
error:
(URL:
[http://localhost:8080/geonetwork/srv/api/records/918/processes/iso19139.gemini23-schemaupgrade?process=iso19139.gemini23-schemaupgrade&id=918](http://localhost:8080/geonetwork/srv/api/records/918/processes/iso19139.gemini23-schemaupgrade?process=iso19139.gemini23-schemaupgrade&id=918)
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
On Thu, Mar 19, 2020 at 4:33 PM Jose Garcia [<jose.garcia@anonymised.com>](mailto:jose.garcia@anonymised.com)
wrote:
Hi Jo
Jose García
On Thu, Mar 19, 2020 at 5:31 PM Jo Cook [<jocook@anonymised.com>](mailto:jocook@anonymised.com)
wrote:
Hi Jose,
Thanks
Jo
On Wed, Mar 18, 2020 at 9:30 AM Jose Garcia [<jose.garcia@anonymised.com>](mailto:jose.garcia@anonymised.com)
wrote:
Hi
folder
upgrade,
the
single
metadata updates.
See
[https://github.com/geonetwork/core-geonetwork/commit/7f22142621c834abc431ac859b06de087962d7f7](https://github.com/geonetwork/core-geonetwork/commit/7f22142621c834abc431ac859b06de087962d7f7)
Jose García
[dev@anonymised.com](mailto:dev@anonymised.com)> wrote:
Hi Jo,
have a
considering.
2014
metadata
metadata
do not
defined
programs
the
database
new
name.  We
to a
export the
content
file
that
that.
Bigger Picture
expect
format,
of
has to
be changed.
Jeff
Hi List,
Thanks
Jo
[GeoNetwork-users@lists.sourceforge.net](mailto:GeoNetwork-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geonetwork-users](https://lists.sourceforge.net/lists/listinfo/geonetwork-users)
[http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
[<http://www.geocat.net/>](http://www.geocat.net/)Veenderweg 136721 WD BennekomThe
NetherlandsT: +31
printing
this email.*
*Jo Cook*
urgent
[<https://astuntechnology.com/company/#email-updates>](https://astuntechnology.com/company/#email-updates) for updates on
news,
[<https://twitter.com/astuntech>](https://twitter.com/astuntech)
[<https://astuntechnology.com/ishare/>](https://astuntechnology.com/ishare/)
[<https://astuntechnology.com/training-courses/>](https://astuntechnology.com/training-courses/)
[https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal](https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal)
864201149.
[<http://www.geocat.net/>](http://www.geocat.net/)Veenderweg 136721 WD BennekomThe NetherlandsT:
+31
printing
this email.*
*Jo Cook*
[<https://astuntechnology.com/company/#email-updates>](https://astuntechnology.com/company/#email-updates) for updates on news,
t:+44 1372 744 009 w: astuntechnology.com [<http://astuntechnology.com/>](http://astuntechnology.com/)
twitter:@astuntech [<https://twitter.com/astuntech>](https://twitter.com/astuntech)
iShare - enterprise
geographic intelligence platform [<https://astuntechnology.com/ishare/>](https://astuntechnology.com/ishare/)
portal
864201149.
GeoNetwork OpenSource is maintained at [http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
Hi Jose,
Yes, that record is a gemini 2.2 record. The xslt
iso19139.gemini23-schemaupgrade is in the Gemini 2.2 schema folder, but it
references an xsl in the Gemini 2.3 folder. I will check it can find that
one.
Jo
On Fri, Mar 20, 2020 at 1:56 PM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Jose García
wrote:
Hi Jose (and list)
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
wrote:
Hi Jo
Jose García
wrote:
Hi Jose,
Thanks
Jo
wrote:
Hi
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
iShare - enterprise
portal
864201149.
That URL is automatically generated by the suggest process, it's not
something I have any control over, as far as I can tell? My xsl works
when using the API.
Thanks
Jo
On Fri, Mar 20, 2020 at 1:57 PM Xiawucha ZZ <xiawucha0908@anonymised.com> wrote:
Hi Jo,
I think the url you're using might be wrong, can you try http://localhost:8080/geonetwork/srv/api/0.1/records/918/processes/iso19139.gemini23-schemaupgrade ? In the swagger api document, it's /api/0.1/records/{metadataUuid}/processes/{process}
I tried to upgrade our iso19115-3 to iso19115-3.2018 using that api, it works. But I'm using version 3.10.1.
Zhuoyue
Hi Jose (and list)
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
> Hi Jo
> Regards,
> Jose García
> wrote:
>> Hi Jose,
>> Thanks
>> Jo
>> wrote:
>>> Hi
>>> metadata updates.
>>> See
>>> Regards,
>>> Jose García
>>>> Hi Jo,
>>>> Bigger Picture
>>>> be changed.
>>>> Jeff
>>>> Hi List,
>>>> Thanks
>>>> Jo
>>> this email.*
>> *Jo Cook*
>> 864201149.
> this email.*
*Jo Cook*
iShare - enterprise
portal
864201149.
Jo Cook
iShare - enterprise
portal
864201149.
Hi Jose,
I think the problem seems to be that the suggest process is using the ID to
generate the URL but the API process in Swagger uses the UUID. If I switch
to using the ID in Swagger then I get the same failure message. Is that
likely?
Jo
On Mon, Mar 23, 2020 at 8:38 AM Jo Cook <jocook@anonymised.com> wrote:
Hi Jose,
one.
Jo
wrote:
Hi Jo
Jose García
wrote:
Hi Jose (and list)
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
wrote:
Hi Jo
Jose García
wrote:
Hi Jose,
easily backport to 3.4? (Happy to give it a go if it's simple enough).
Thanks
Jo
wrote:
Hi
metadata updates.
See
Jose García
Hi Jo,
other questions, and potentially results in a "best practice" that I will
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
*Jo Cook*
iShare - enterprise
portal
864201149.
Hi Jo
Ideally should be indifferent using id or uuid as should match the same
record, but will check the issue loading the GEMINI 2.2 schema.
Jose García
On Mon, Mar 23, 2020 at 10:15 AM Jo Cook <jocook@anonymised.com> wrote:
Hi Jose,
to generate the URL but the API process in Swagger uses the UUID. If I
switch to using the ID in Swagger then I get the same failure message. Is
that likely?
Jo
wrote:
Hi Jose,
one.
Jo
wrote:
Hi Jo
GEMINI 2.2 schema and the metadata with the id 918 is a GEMINI 2.2 record
correct?
Jose García
wrote:
Hi Jose (and list)
struggling with getting it working as a suggestion. With the files from
error:
(URL:
<apiError>
<description>
Processing failed
</description>
</apiError>
Thanks
Jo
wrote:
Hi Jo
Jose García
wrote:
Hi Jose,
Thanks
Jo
wrote:
Hi
metadata updates.
See
Jose García
Hi Jo,
Bigger Picture
be changed.
Jeff
Hi List,
Thanks
Jo
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
864201149.
this email.*
*Jo Cook*
*Jo Cook*
864201149.
this email.*
